Tip for alt parts to replace H-arm, LXT outer hinge and hub
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
I am currently going through all the manuals and explodes for 14 different old models. Trying to make a compatibly chart for parts.
The GTX NXT explodes opened my eyes on an alternate for the H-Arm and LXT arm outer hinge pins a2023. I am sure someone else probably knows this, but thought I would share with others who didn't know. EDIT Also could be used to replace missing old hubs, since you are using the CR hub. (DUH)
The C Clips, Hubs and the Hinge Pins are only at places with old inventory. If you don't want hunt for those you can use these parts instead.
a2007 hinge pin (which is used in the 5 link, XX and XXX models)
a2126 XX CR Hub
a5050 shock spacers (which you probably already have)
Refer to the NXT explode to see how it works.
http://vintagelosi.com/Manuals_files/nxt.pdf
This process has also opened my eyes to all the error and omissions in the manuals and explodes. There are lots.
EDIT This might only work with XX/XXT retrofit transmissions using the normal XX/XXT dogbones. May not work with LRM transmissions and the sliders.
Return to “Losi Forum”
