PROJECT RC10T2 RUNNER
m_vice
Post by m_vice »
This is my latest grab, it started as a RC10T2 Sport and it came with a MIP converter tranny for another project. This is going to be a runner and I am adding some modern parts to it for the fun and test of it.
BEFORE:
It is mainly stock, added bearings and some Lunsford Ti.
In the transmission I replace the original black ideal gear with a new one and I replace the slipper clutch system with an SC10 new slipper (I am using the old parts for a shelf car I am planning on). I am also using B4 rear CVD axles, LC ball cups and T4 front steering block carrier assembly making the truck a bit wider than original.
That is some strong flash on the cam.
The truck was in great conditions, It has some scratches but It looks like it was ran and never really taken apart after that. I think that this helps keep the parts in better conditions for a re-built.
- The clean up
- The rebuilding of the transmission
- SC10 slipper with top shaft
- Remember to add the T2 spacers in the inside to the sc10 top shaft.
- The built up
- I cut the front nose plate and I am making a custom bumper for it
- JConcepts ball cups
- sc10 front parts
I am rebuilding the shocks; they have the older round cap seals that I am re-using on another project.
I am looking for some new white Pro-Line rear wheels and bar codes rubber and I am planning on using a T3 Pro-line crowd pleazer body, I always love that body but never got one until now.
:D
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Re: PROJECT RC10T2 RUNNER
Post by littleVETTE »
looking real good miguel. can't wait to see what it looks like finished.
m_vice
Post by m_vice »
Pro-line crowd pleazer Body for T3, not sure on the fit yet and I need to add some spacers to the body mounts to bring it up a bit.
Zipster
Post by Zipster »
Looks great! I just picked a NIB one up recently and once I get done savoring the parts all shiny in their little baggies (I've never really built an RC car from new), I'm going to build it into a runner as well (although I have this warped idea floating around in my head of building it into a big ridiculous buggy.... That said, I like the way that body looks on it. Can't wait to see it painted.
SRTracer121
Post by SRTracer121 »
wow that looks great! im loving that tub :D
had one of the gt2 versions of the crowd pleazer on my pede years ago never liked the lights on those bodies but the rest of the lines on it are just wicked
m_vice
Post by m_vice »
Update:
Got some Losi rubber and pro-line wheels and kind of located and marked the body location. I am liking this but I wander if I should try one of the newer modern T4 bodies like the JC one and save this one for when I get a T3 ( I plan to run this one).
I used Duratrax servo mount I had to extend the rear body post location.
Has thanked: 365 times
Been thanked: 485 times
Mig, the JC Highflow is a direct fit if you use the B4 wingmounts in the rear bodymount locations-
You'll love that as a runner, don't be afraid to use the Robinson Alloy diff gear and hardened idler in it :wink:
m_vice
Post by m_vice »
I like the JC Highflow so I think I am getting one, or go with one of the other like the ponisher...
ljh501
Post by ljh501 »
Love it! Looks great. My favorite ride for sure, and likely have invested too much in mine 8) =/
What SC10 parts are you using up front??? The castor block, the knuckle or both? Any modification needed?
Thanks!
rc10johnny
Post by rc10johnny »
Nice BUILD "MIG"....... :mrgreen:
delsami
Post by delsami »
what do the j concept rear ballcups achieve??????????? why use them, i have never seen them before?
m_vice
Post by m_vice »
delsami wrote:what do the j concept rear ballcups achieve??????????? why use them, i have never seen them before?
I only use them because I had a short rod and these work well with it… The real upgrade is when you use them on the rear of a B44 because it helps clear the inside of the rear wheel during jumps and rough terrain driving.
tak555
Post by tak555 »
hey there, great pics and write-up so far... i'm in the process of restoring a RC10t2 myself and have a couple questions i'm hoping you could help with...
1. what are you going to do for power? i'm thinking of dropping my velineon in it... any suggestions for pinion gear???
2. for the jconcepts ball cups, what length tie-rods did you use in the rear? it looks way shorter than stock (due to the longer length rear cups).
keep us updated on your build! thank you!
ljh501
Post by ljh501 »
Looks great!
Nice ribs up front. Anyone ever try holeahot T's or similar front and rear?
Return to “RC10 Truck Forum”
Users browsing this forum: No registered users and 22 guests
