Rebuilding and refilling red Kyosho shocks - How?
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
I'm trying to rebuild two red Kyosho shocks from an early Optima. They will be mounted to a CRP front suspension kit on a Tamiya Striker :D . However, after three tries at rebuilding them, I gave up because of two problems:
1) The o-ring seals are shot. The shocks leak terribly. :cry: Can I replace the o-rings by Tamiya o-rings, or did Kyosho use o-rings with different dimensions?
2) How far are you supposed to fill these things with oil? The first two times I tried I couldn't get the cap fully on (could not be screwed down), and the third time I had a shock that had zero rebound while the shock shaft could not slide further than halfway up the shock body... :evil:
Could someone please help and tell me how you are supposed to rebuild these things?
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Re: Rebuilding and refilling red Kyosho shocks - How?
Post by Hcp22 »
You will find new O-rings at CRP (http://www.teamcrp.net/).
Follow the instructions on the picture! :D
Cheers
Lars
My Feedback
treehugger
Post by treehugger »
i managed to snag a set of progress shocks a few weeks back and like the bleed screws.
it looks like an easy mod drill and tap :wink: ive been thinking of doing it to a pair of gold kyoshos i have .
as easy as the instructions look i still srtugle with shock rebuilds :cry:
Paul
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
Does bleeding work in combination with the air cap in the kyosho gold shocks? if you put the bleedport in the wrong place it will just bleed air ;)
Or you could take the bladder out...
Hcp22
Post by Hcp22 »
Back in the days, we drilled a tiny hole in the gold shocks top cap … that wasn’t such a god idea, when the buggy landed after a big jump four squirts came from the shocks when the air caps burst :lol: :lol: :lol:
Cheers
Lars
My Feedback
EvolutionRevolution
Thank you for the instructions! That will certainly help. :D
I tried rebuilding some Kyosho red shocks that were originally installed on the Marui Galaxy I restored, and I must've had bad O-rings too, as they just leaked. I also found they were picky with the amount of oil needed; a little too much and they wouldn't compress.
Now I have a full set that I'm not using.
rangerg
Post by rangerg »
I know MikeDealer had a link to reproduction red shock collars, but they aren't sold anymore. Any other ideas? I have a great set of red shocks, but all have broken collars. Thanks for the help!
bdrmbully
Post by bdrmbully »
crappy shocks!! look into investing your $ and time into a better more useable shock lol
2nd place is just the 1st loser
EvolutionRevolution
bdrmbully wrote:crappy shocks!! look into investing your $ and time into a better more useable shock lol
Anything will be an improvement over the Striker's front springs. They are also the only shocks I have that actually fit decently - small enough and not too long.
rangerg wrote:I know MikeDealer had a link to reproduction red shock collars, but they aren't sold anymore. Any other ideas? I have a great set of red shocks, but all have broken collars. Thanks for the help!
Though I agree with the others that the red shocks are pretty finicky and probably only useful protecting the car from "shelf shock"... :lol:
You do have some options.
Plastic:
http://cgi.ebay.ca/8mm-SPRINGS-COLLARS-Kyosho-Optima-Icarus-RC-CRP-1515-/230578787142?pt=Radio_Control_Parts_Accessories&hash=item35af911346
There's also a guy selling red alloy retaining rings similar to the above, but I can't for the life of me find one on eBay right now...??
Mr. ED
Post by Mr. ED »
clinehobbies has replacement shocks in different colors and with machined collars.
No idea how they work though.
rangerg
Post by rangerg »
thanks coelacanth - I'll check those out
bdrmbully
Post by bdrmbully »
those crp collars are too small for the red shocks i got suckered into those as well. dont even think they fit the gold shocks similar to the red ones. waste of money!! wait for a pair of hot trick or similar the chinese seller is not around anymore. i got some on an ultima before the seller closed up shocp. sell you a whole ultima for 120 shipped lol...
bdrmbully
Post by bdrmbully »
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarGoogle [Bot] and 2 guests
