need help finding a thread
bigmd
Post by bigmd »
hey guys yesterday i did a search for "modern wheels" and it brought me to a thread that listed parts from a Thunder Tiger Phoenix.It had part numbers and a website to get them.Well today I do the search again and its nowhere to be found.anyone know what im talking about?the guy that started it said he talked to a former Associated employee and he gave him part numbers to use todays 2.2 wheels.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: need help finding a thread
Post by JK Racing »
bigmd
Post by bigmd »
holy crap that was fast.thank you.i searched for hours.
JK Racing
Post by JK Racing »
Its a common question, and I used the info in there to help me.
another good thread, same section
http://www.rc10talk.com/viewtopic.php?f=38&t=10403
bigmd
Post by bigmd »
JK do you know if the parts from the Phoenix will work?
JK Racing
Post by JK Racing »
Personally, I would get the Phoenix rear wheels, use a body reamer to open them up ever so slightly to fit the 1/4" tapered axles and the duratrax front wheels. Run the car box stock with just those 2 changes. If I hadnt invested so much into B4 wheels all around already, I would be doing that exact set up.
bigmd
Post by bigmd »
really?ok.so with that setup i could run the cvds for the rear?
JK Racing
Post by JK Racing »
You could run "standard" MIP CVDs, stock Universals or the stock Dogbone/Axle combo.
If you really dont want to modify the rear wheel (I did it for a buddy, truly took about a minute each wheel), B2/B3 CVDs, change the bearings and bolt the Phoenix wheel right on.
I dont know about the Phoenix CVD/Universals.
bigmd
Post by bigmd »
ok cool.yeah thats what I meant,either mip's or the stockers
JK Racing
Post by JK Racing »
Good luck and post pictures :mrgreen:
bigmd
Post by bigmd »
JK while I have you do you know the best way to convert to ball bearing steering bellcranks.I located another thread where someone listst associated part numbers but i cant seem to find it.thanks
JK Racing
Post by JK Racing »
I was lucky enough to find 2 donor cars with Losi (on one) and Houge (on another). I havent had to find current ball bearing offerings that work.
I remember that thread also, using a combination of GT and B3/T3 parts if memory serves me (which it doesnt do very well any more!)
Occasionally, a member here (Atlas) has what appears to be a copy of the Losi ball bearing steering (in gold anno) available for purchase.
bigmd
Post by bigmd »
thanks for your help.i found everything i need.you wouldnt happen to have to short noseplate screws would ya?part number 7306.
JK Racing
Post by JK Racing »
the little one for the middle? i usually just cut down a long one :)
bigmd
Post by bigmd »
