Andy's Arms- ??S on axles
General info, Q&A.
muck
Post by muck »
I want to use my Andy's arms off my graphite chassis. Are the B44 cvd still the correct length?
I see some using RPM GT rear hubs, any mods to fit those on the rear?
On the fronts, i see some using B4 hub, knuckles, and spindles. Will these fit with the Andy's?
thanks
Has thanked: 358 times
Been thanked: 470 times
Re: Andy's Arms- ??S on axles
The arms and GT hubs will not accept the B44 CVA/CVD the axel is way to long- you would need to use a B2 CVD with the 3/16 axels to use that combo
muck
Post by muck »
Charlie don't surf wrote:The arms and GT hubs will not accept the B44 CVA/CVD the axel is way to long- you would need to use a B2 CVD with the 3/16 axels to use that combo
shoot. I thought because the arms where longer than the stock ones they would work.
So if i stuck with the dog bone i have, is there an outer spindle to use?
Maybe i should ask this, is the dogbone that came on the edinger arms going to work on the Andy's?
thanks
Yes but they are 1/4 in axels and you can forget using any current wheels. But you can get SC10 RTR dogbone outers that are 3/16 and use them
muck
Post by muck »
ok, to recap then
using Andy's arms,
the stock dog bone from the edinger, sc10 spindle, GT hub?
sorry just want to make sure i am where i need to be with it..
thanks
muck wrote:I thought because the arms where longer than the stock ones they would work.
andy's arms are the same length as stock rc10 arms, not longer.
