10T to buggy??
- Regular Member
10T to buggy??
ok dumy question here,,,i have a pan 10T and am thinkin bout doin a latemodel but i have to be under 10.25" wide and 11.25" wheelbase i know i can shorten it by using the other set of front holes in the pan, however its the arms and acc. that i will need to make it this width. does anyone know the width and wheel base of a pan buggy? or if someone has an extra set of arms and drive shafts connecting rod acc. etc. lemme know what i need please thank you soo much!
- Has thanked: 36 times
- Been thanked: 1319 times
Re: 10T to buggy??
just go out and buy a used buggy. it'll be cheaper in the long run.
but if you must convert your truck, you need:
shorter shocks
shorter towers
shorter tie rods
buggy steering bellcrank
shorter arms
shorter cvd's
shorter shocks
shorter towers
shorter tie rods
shorter arms
shorter cvd's
- Regular Member
Re: 10T to buggy??
lol thanx well i knew that..
im kinda wantin to know part numbers if possible, i would jus like to convert the truck so itll kinda be 2n1 and it can always be put back and take up less space. the wifes already moanin and groanin about the cars i have lol thanx for the response!
Re: 10T to buggy??
ok her you are everthing you will need # wise ,but scr8p is correct buy a buggy alot cheaper and you get a pile of spares
http://lowclasscc.net/downloads/
http://www.theshreves.com/rc_stuff/rc10history.htm
- Regular Member
- extreemduster340
Re: 10T to buggy??
I like to buy 10t's because they have stealth trans and are usually in better shape then most buggy's you see for sale. I have 2 trucks I have converted over to buggy's. One uses the dynotech a arms and the other has a buggy nose plate on it with stock rc10 arms. Nice thing with the dynotech arms is that you can use the truck nose plate and bulkhead. If you have the truck I would convert it even if you have to buy the parts. In the end you will basically have a new vehicle thats nice and tight. Depending on the route you decide I may be able to help you with some of the parts (shocks, cvd's, shock towers etc.) I would buy new arms and mounts they are cheap.
Jamie
Jamie
- 1486 Views
Last post by ericsp2
- 1645 Views
Last post by Sixtysixdeuce
- 37 Replies
- 6407 Views
Last post by Jim85IROC
- 735 Views
Last post by TycoTamiya4eva
- 22 Replies
- 4405 Views
Last post by Frankentruck
- 950 Views
- 1789 Views
Last post by Gastruckracer14
- 853 Views
Last post by tulsa
