Motor ?
Motor ?
I just got an RC10 I won on Ebay and I'm in the process of restoring it. It came with a blue motor having a sticker that reads Speed Gem 2. Can you folks give me an insight as to the best gearing? Thanks for your time and hope you have a great weekend.
In Christ,
Joel C.
Joel C.
Re: Motor ?
Also, the previous owner drilled tons of holes on the bottom of the tub. What is the best way to cover them up? Thanks again.
In Christ,
Joel C.
Joel C.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: Motor ?
I dont know about that motor, Sapphire maybe? Try searching speed gems motors to find the windings and then helping with gearing will be easier.
For the holes in the chassis, you can use chassis tape (AE, JConcepts & others) to seal the holes on the bottom, that should help. For a more permanent fix, not sure, JB Weld or something?
If you go the chassis tape route, you can custom order a chassis wrap from Upgrade-rc.com
Re: Motor ?
Thanks JK Racing. Just curious though, how durable is that skin? How is it applied? Thanks for the motor info. Bro.
In Christ,
Joel C.
Joel C.
- Been thanked: 4 times
Re: Motor ?
17 TURN SINGLE WIND if memory serves me correctly.Chassis protection film is like a tuff thick decal peal it off backing and stick it on chassis bottom.DON
- JK Racing
Re: Motor ?
the stuff from upgrade is motocross grade and pretty thick.
- 1399 Views
Last post by WriteDean
- 2089 Views
Last post by uniquenamehere
- 2325 Views
Last post by MelvinsArmy
- 2360 Views
Last post by Dadio
- 3099 Views
Last post by oneyedog
- 869 Views
Last post by coxbros1
- 2175 Views
Last post by R6cowboy
- 1150 Views
Last post by treehugger
Users browsing this forum: Google Adsense [Bot] and 2 guests
