What's a good modern replacement for the gear cover seal on an Optima/Ultima? (I tried cutting foam tape and it didn't work well)
What's a good modern replacement for the battery strapslon an Optima/Ultima? (Rubber bands work, but I want something better looking and more like the original straps)
Thanks for the help!
Modern battery straps and gear cover seal?
Re: Modern battery straps and gear cover seal?
i use the red servo tape from home depot for the trany cover seal .
clean up the cover cut some long strips 3mm wide, and go round the perimiter of the trans cover a couple of times . when you tighten up the 4-40,s it seals up air tight
I bought some battery straps on ebay a year or more ago... not sure if they were original parts but were nearly identical to the originals. I have seen them at least one other time since. Also I came across some almost exactly the same that came with a Dell server for work to wrap up cables, they must be available somewhere. I have never seen any that width at Home Depot or any other home improvement store. Good luck.
- 5227 Views
Last post by mk-Zero
- 1224 Views
- 1417 Views
Last post by upforit365
- 969 Views
Last post by transamman908
- 1948 Views
Last post by Weave
- 2071 Views
Last post by SoloGraphix
- 1557 Views
Last post by Lonestar
- 23 Replies
- 2726 Views
Last post by chophead69
