Dying parts
Dying parts
Dont know if this is the correct place to post my question, but how are you guys dying your parts? And can parts already dyed become black easily?
Thanks
Thanks
Re: Dying parts
Dye parts just like you were dying cloths. I went to the thrift store and bought a old sauce pan for $2.00, add the dye, water and salt - bring to a boil , add your parts. The longer you boil the darker the color. I would say "Yes" black should cover most other colors. "Good Luck"
Craig
Craig
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: Dying parts
if your bbq has a burner, then boil on that. otherwise you'll have some splainin to do to the wife when she finds black specks of dye all over the kitchen
Re: Dying parts
QTF!!shodog wrote:if your bbq has a burner, then boil on that. otherwise you'll have some splainin to do to the wife when she finds black specks of dye all over the kitchen
I just got done dying a bunch of parts black and red. I just used boiling water and put it in a couple of plastic shoe boxes and let the parts sit for 24 hrs and they came out great. Even with three large towels and being careful with it on the kitchen counter my wife still manged to find black and red splotches two three feet away on the walls and fridge, needless to say she was not a happy camper with me. Ooopssss.
Lynn
- shodog
Re: Dying parts
What happens is the water and dye steam off and wherever it settles your going to get a little dot of dye
Re: Dying parts
I've heard about some people placing the parts to be dyed in a plastic bucket, adding near-boiling water, mixing in powdered or liquid dye, and monitoring until the desired depth of color is achieved. I imagine that it takes a little longer for the dye to penetrate, but the risk of mess is much less (no actively boiling water with dye).
Re: Dying parts
and now i wish i bought the pan with the lid from GoodWill.... i thought i was doing good with a $.99 pan....
So do i let it simmer or actually boil for a bit.
- THE H.P FREAK
Re: Dying parts
HI!... I do the following :
- Boil water in stainless steel pot
- once water boils, turn down the the heat to simmer
- Pour in the RIT dye and stir well
- drop parts in and occasionally stir
- keep in pot for about a hour
- remove parts and wash under warm water from tap
- let dry
- use
- let dry
- use
- Been thanked: 325 times
Re: Dying parts
I'll add my observations, when I dyed a set of white nylon Turbo Optima wheels. It's generally recommended to leave your parts in the dye until you reach the depth of color you're looking for; a few minutes for light blue or 20 minutes for dark blue, for example. I was looking to get a fairly light, pastel blue color. However, I found that the dye didn't quite "sink in" after only a few minutes. Rather, it was somewhat splotchy. It needed a certain minimum amount of time for the wheels to get a consistent blue dye. By the time that minimum time expired, the wheels were quite a bit darker than I wanted.
Other than that, I followed H.P Freak's method, which pretty much sums up what I read over on RIT Dye's website.
Re: Dying parts
make sure you have all thread lock or glue off parts, it will not dye that.. found that out tonight dying old buggy parts that where a funny color..
- Monkeyman2500
- Zipster
- Been thanked: 5 times
Re: Dying parts
So, uh, ProLine wheels don't dye so well, do they?
I now have freshly re-dyed black pieces and some pretty dark purplish-blue wheels....
What similar wheels dye better? (these are just wide whites for B4 axles).
I mean, they look nice, but not exactly the effect I was going for
Re: Dying parts
I just dyed a batch of old parts black and they came out with a blueish tint. I boiled the water then dumped the boiling water and dye into a pan with the parts and let sit a while. This is the way I had done it in the past. The dye didn't take that well maybe because the parts are older and more brittle?
Going to try another batch tomorrow and will let this one simmer on the stove and hope the warmer water makes the dye cover better. Or any other suggestions?
Re: Dying parts
Ok second try came out much better. Difference was on the 2nd one I kept the water simmering instead of cooling. Not sure if it mattered but the first batch was RIT liquid dye, the second was powerded.
- wait a minute
Re: Dying parts
If I remember back in the day I think Parma sold little packages of fluorescent colors. They were in little plastic containers.
actually i believe it was paragon and not parma.
wait a minute
- 978 Views
- 22 Replies
- 2006 Views
Last post by Dr. Robotnik
- 1249 Views
Last post by badhoopty
- 23 Replies
- 4887 Views
Last post by longboardnj
- 2274 Views
Last post by urpaldan
- 722 Views
Last post by asashaw
- 1317 Views
Last post by treehugger
- 2078 Views
Last post by sk7
