Removing chrome *only* from rim channels
I kept meaning to ask this but was always forgetting... :?
A lot of nylon wheels are chromed, but CA glue doesn't stick very well to the chrome plating. Does anyone have tips for removing chrome *only* from the bead channels of the wheels, so that tires will adhere properly? I'm sure it could be done carefully with a Q-tip & acetone--is there an easier way?
Has thanked: 33 times
Been thanked: 1188 times
Re: Removing chrome *only* from rim channels
sandpaper
Ugh...I said easier. :mrgreen: I've removed chrome plating from plastic arm-rest bases for my 1:1 Charger and it's a major PITA. :x
wire wheel bit in a dremel, scrape it off with an xacto........
THE H.P FREAK
Post by THE H.P FREAK »
HI!... I have a sand blasting cabinet in my garage. I have it filled with fine glass bead. Works great on all kinds of RC plastic and aluminum. I can take the chrome off the channels you mentioned in about 5 minutes for 4 rims. :mrgreen:
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Post by Y'ernat Al »
Coelacanth wrote:Ugh...I said easier. :mrgreen:....
Nut the wheel onto and old axle and the put that into the end of a drill chuck. Pull the trigger on the drill and run scr8p's sandpaper along the bead.
- Brian -
My Gallery
Now that's what I'm talking about! Thanks for the tip!
LTO_Dave
Has thanked: 52 times
Been thanked: 284 times
Post by LTO_Dave »
Automotive brake parts cleaner eats chrome. I stripped a set of AE TQ wheels that were peeling. :wink:
