Striker Sonic Fighter FX10 arms on Grasshopper/Hornet ???
- losiXXXman
- Been thanked: 5 times
Anyone know if it can be done? I went to GH2 arms on my hornet for width, but seems like I sacrificed some rigidity.. they twist like a 50's dance craze. These look a little more stout..
Re: Striker Sonic Fighter FX10 arms on Grasshopper/Hornet ??
it sure can be done:
i really need to get on the ball and take some finished pics. i replaced the solid upper bar with threaded 4/40 rod and dubro ends, as the uppers that come with the crp front suspension kit are too long. you also need to trim the ends of the arms where they mount inboard (the built in hinge "pin") as they are a bit to long. you'll also need longer steering rods. if you buy the kit from team crp you need to also get the hardware kit (they split them up). and shock of course, dodn't get the ones i have they are period correct and don;t work well and they leak.
it really helps wake the car up, now i can turn at a reasonable speed without flipping. a little weight added to the back of the chassis helps too.
- losiXXXman
Thanks Kaiser. Now that I think about it, I knew about the CRP kit, and I knew it could be adapted to the GH and Hornet. Guess I should have put 2+2 together
- 1694 Views
Last post by trackjunkie600
- 1880 Views
Last post by coxbros1
- 2553 Views
Last post by Fred19K
- 2205 Views
Last post by Dom79
- 905 Views
Last post by TokyoProf
- 1602 Views
Last post by dsmith
- 863 Views
Last post by gula
- 1009 Views
Last post by lebowski770
