thanks
Will do Thanksbormac wrote:The early Yoke's are cool. I managed to source a nice little pile of parts for this model, if you run short of anything drop me a PM.
I think it is a YR-4 shocktower that's used as a replacement for a broken 870C onescr8p wrote:the tops of the rear shock tower were broke/cut off, and they attached the shocks in the wing mount holes.
Thanks. Ill let ya know on the tower, I actually won two YZ's so ill see what i can make of both lolNRG wrote:mounting rear shocks to wing mounts is common when the old mounts are broken. Have done this myself in the past.
if you want a new rear shock mount let me know as i have one NIP and it wont cost you all your possesions![]()
front shocks seem to have rear springs on them too, andy's lower armsbutchered bulk head covers are so bits dont get stuck and tear the belts to shreds.
Should look good after a strip and clean
