Painting ? help needed
- Been thanked: 81 times
I am doing a body that has some hard to reach places in it . So I might have to paint on the outside of the body. What do you guys recomend. The guy at the hobby shop said he used faskolor topped off with mop&glo floor wax to get the gloss look .
- Eau Rouge
- Been thanked: 5 times
Re: Painting ? help needed
The only time I paint on the outside of Lexan is for dull finishes, like flat black or aluminum trim. If you are absolutely certain you have to paint on the outside (I honestly don't ever think I have had to do anything like that in 26 years), and you are looking for a gloss finish, there is a clear middlecoat made by AutoAir (Createx/Faskolor), and there is also a Faskolor version that you can use as well. It's water-based, and WILL come off if you clean or wash the body. There really is no good solution for this, because Lexan has always been intended to be sprayed from the inside.
- HotRodJosh
- Has thanked: 3 times
If ya just "have" to paint lexan on the putside and want it glossy, just use a cheap automotive clear...like Dynatone or Upol.
"I've got a fever, and the only prescription.....is more cowbell."
Pinstriping by Josh
Pinstriping by Josh
- THEYTOOKMYTHUMB
- Has thanked: 3697 times
- Been thanked: 1978 times
I'm not sure if it would work the same on Lexan, but this has automotive clear coat on it. It's much shinier in person than it appears in the photo. Had to dig this one out from the deep as you can tell by the date...
Still alive and well though!
- extreemduster340
I have a little different approach when it comes to painting on the outside. I always trim my windows, stripes and flames from the outside using One Shot lettering enamel. It doesnt last for ever but neither do lexan bodies if you run them. I will post picts up in a few.
Jamie
Jamie
- 519 Views
Last post by THUNDERSTRIKE1
- 2253 Views
- 953 Views
Last post by Bormac
- 1715 Views
Last post by rctenracer
- 2382 Views
Last post by NomadRacer
- 1168 Views
Last post by Vintagemishal
- 760 Views
Last post by SRTracer121
- 509 Views
Last post by RC10resto
