i just scored a 10t
i just scored a 10t
a buddy of mine (who commutes with me) just paid me for gas with a nice 10t.
it's an early one i think, all white parts.
i've been searching the forum for a while with no luck. i have a few questions:
it's got dog bones and they have got to go, will t2 cvd's work?
if not i have read that we can use t4 hubs and t4 cvd's, correct?
i'm going to get a topshaft from a b4 so i can use the newer slipper. i noticed the b4.1 top shaft and gear look a bit different, like the gear is plastic.
should i stay away from that or is it ok to use? ratio the same on the b4.1? (rc10.com's manuals only list the b4.1 now so i can't check part #'s to see if it's the same as the original b4)
any input/opinions are appreaciated.
pete-
pete-
- slotcarrod
- Been thanked: 45 times
Re: i just scored a 10t
You can use T2/GT CVD's but make sure you have the correct bearings, off the top of my head 3/16 x 3/8. Here is the CVD set : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAW07&P=7 These CVD's will fit any modern T3 or T4 wheel.
If you have 1/4" bearings and want to use your original wheels, you will need this CVD, but it's discontinued : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAV74&P=7
The B4 top shaft works fine, the tooth count is the same on both! The B4 ratio is 2.6, your Stealth is 2.25. The difference is in the tooth count of the idler and the diff gears not the top shaft.
Rod Littau
- acerpower1
I have the old 1/4" CVDs, and I was wondering if it would be possible to convert them to the 3/16" CVD by using this part http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAW08&P=SM rather than buying all new CVDs.
- slotcarrod
Yup!acerpower1 wrote:I have the old 1/4" CVDs, and I was wondering if it would be possible to convert them to the 3/16" CVD by using this part http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAW08&P=SM rather than buying all new CVDs.
BTW, Tower uses their own part numbers!
Always try to support you local hobby shops first, if they don't have it then get it online!
Rod Littau
so if i go with t2/gt cvd's and change the bearings i can use my og hubs? and then i can run modern wheels, right?slotcarrod wrote:You can use T2/GT CVD's but make sure you have the correct bearings, off the top of my head 3/16 x 3/8. Here is the CVD set : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAW07&P=7 These CVD's will fit any modern T3 or T4 wheel.
thanks for your help rod.
- slotcarrod
Yes you can use original hubs with those bearings and axle, the original wheels will also fit the new axle but not the best fit. I would get one piece wheels for the T3/T4.kaiser wrote:so if i go with t2/gt cvd's and change the bearings i can use my og hubs? and then i can run modern wheels, right?slotcarrod wrote:You can use T2/GT CVD's but make sure you have the correct bearings, off the top of my head 3/16 x 3/8. Here is the CVD set : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAW07&P=7 These CVD's will fit any modern T3 or T4 wheel.
Your welcome!
Rod Littau
damn, avid's out of the 3/16 x 3/8.
i'll have to get them from someone else, no biggie.
thanks again, i can't wait to get this sucker going.
i have a pair of shiny t2/gt cvd's on the way.
- slotcarrod
Try Boca Bearings, if you must get them on line. Your local hobby shop should have them in stock, very common size for AE and Losi cars!
Rod Littau
This Duratrax set for the B3/T3 will also work:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD033&P=7
It's weird, a set with thirteen 3/16x3/8 bearings (and bearings for the diff) is the same price as ten 3/16x3/8 bearings alone.
You can fit wheels with a 12mm hex on the rear with these from HPI:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN057&P=7
And you can mount front wheels that use an 11mm bearing with these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN055&P=M
thats where i got them, i used to always use boca, until i found avid.slotcarrod wrote:Try Boca Bearings, if you must get them on line. Your local hobby shop should have them in stock, very common size for AE and Losi cars!
thanks for all the advice guys, if you have any more "tricks" or must do mods post them up.
b4 top shaft and slipper just arrived, with an 81 tooth spur.
what are you guys running as far as gearing goes?
pinion and spur for say an 8.5t novak ballistic?
any help is greatly appreaciated.
- Been thanked: 5 times
With the 3/16" axles you can use any wheel for the T2, GT, GT2 or T4 that are made for a 3/16" axle. The T3 wheels have a different off-set.
i got a set of prolines made for the t4.
any insight on gearing this bad boy?
- 1992 Views
Last post by Kayne
- 548 Views
Last post by soniccj5
- 19 Replies
- 2327 Views
Last post by treehugger
- 953 Views
Last post by AscotConversion
- 670 Views
Last post by slotcarrod
- 1188 Views
Last post by FasterLouder
- 2317 Views
Last post by bigmd
- 3374 Views
Last post by jasen
Users browsing this forum: Amazon [Bot] and 5 guests
