Soldering Iron Recommendation
- bscotti
Well, my iron has finally died. So, I'm wondering what one you guys suggest. I'd like it to have enough oomph to assemble battery packs and and connectors.
- Has thanked: 36 times
- Been thanked: 1318 times
- Been thanked: 12 times
I have 3 irons that I use.
a 15 watt grounded fine tip for small electronics work:
http://www.radioshack.com/product/index.jsp?productId=2062728
a 40 watt for general use:
http://www.radioshack.com/product/index.jsp?productId=2062738
and a 60 watt used mostly for batteries
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPR36&P=7
I also use one of these stands:
http://www.radioshack.com/product/index.jsp?productId=2062740
It would probably have been smarter to get a good adjustable iron, but all of the above only costs about $30
-Anthony
-Anthony
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
When I was doing some mechanics for a slotracing team I used the solder station from Weller.
With siver solder it was a must
(the pinion had to be soldered on the moter and the moter onto the chassis: a slab of Steel sheet.)
These things will guaranteed solder tabs and wires onto a cell before the cell heats up.
- Mr. ED
I used the stations for the slot cars, no problem there.FlyinGN wrote:DON'T get a weller soldering gun.. They are only one for a minute then automaticaly go off for 5 minutes!! Horrible.I threw my new one away i hate it so bad.
The protection on the guns must be a """new""" thing.
My own weller solder gun is older than my oldest car (about 20 years!)
well. I owned an old weller gun (about 25 years old) and I thought it was going bad. It was hot and then cold.. hot then cold. Nothing was said about that in the instructions. I threw it away and bought a new one. IN the new instructions it DID mention that feature. Horrible idea.. They BOTH did it..
THE BEST IRON TO SOLDER BATTERYS AND SUCH I USE A LEADING SOLDERING IRON THAT YOU CAN FIND AT HOBBY LOBBY OR A CRAFT STORE, ITS A MONSTER 100W IRON SOLDERS BATTERY AND WIRE LEADS SUPER QUICK W/O HAVING TO HEAT UP WHAT YOUR SOLDERING AND ARE ONLY ABOUT 20 BUCKS OR SO . AND FOR NORAMAL USE I HAVE A HAKO 936
- 1655 Views
Last post by RC10th
- 975 Views
Last post by shodog
- 1865 Views
Last post by PBR Allstar
- 1676 Views
Last post by Diamond Dave
- 28 Replies
- 1718 Views
Last post by badhoopty
- 601 Views
- 2028 Views
- 769 Views
Users browsing this forum: Mojeek [Bot] and 6 guests
