Mid Custom Special ' SLIPPER' ideas.
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
Im looking to fit a slipper assembly to my Mid Custom Special vintage racer.
Im not looking for an ultra modern solution with B4 spurs or anything but if anyone might have a suggestion to help me fit 'ROBINSON' type spus that would be great.
Cheers-Jason
-Jason.
Still known as- bormac
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: Mid Custom Special ' SLIPPER' ideas.
Post by Mr. ED »
Fitting robinson type spurs is not hard, but it conflicts with your desire to put a slipper on I think.
Doesn't the custom special already have that tiny slipper 2 metal plates and 2 little disks of what looks like sandingpaper?
rangerg
Post by rangerg »
Use vintage wheels and tires and don't glue them :-)
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
rangerg wrote:Use vintage wheels and tires and don't glue them :-)
Or worn-out tiers :lol:
Cheers
Lars
My Feedback
Bormac
Post by Bormac »
Yeah the original slipper isnt much (in my opinion) but its more so the fact I want to fit aftermarket spurs.
Thanks for the suggestions with the tyres guys......... :lol:
-Jason.
highwayracer
Been thanked: 6 times
Post by highwayracer »
hey Jason,
On one of my optima mids, I used and A&L slipper. To do this, you have to fabricate a new top shaft...but it's really easy to do. Below are the parts you'll need:
A&L slipper
Grasshopper rear axle
5mm x 8mm bearing
Larger spring to fit over the top shaft. You can probably use one from a traxxas slipper.
4mm wheel nut holds everything in place
Standard 48 pitch spur gear
I was on ebay trying to find the parts list and I just realzed that you can probably use a standard traxxas slipper. You'll just have to modify the top shaft to make sure that it fits the mid.
http://cgi.ebay.com/Traxxas-1993-8-Slipper-Clutch-Soft-B-E-/120481005532?pt=Radio_Control_Parts_Accessories&hash=item1c0d3a3fdc
http://cgi.ebay.com/Traxxas-4615-Slipper-Clutch-Set-Nitro-Rustler-Stampede-/330452591478?pt=Radio_Control_Parts_Accessories&hash=item4cf0826376
Regards,
Roger
Bormac
Post by Bormac »
I really appreciate you taking the time to let me know of your idea. Thankyou Roger :D :D :D
-Jason.
Mr. ED
Post by Mr. ED »
If you don't need a slipper: trinity made a small busshing that fits the center of a standard spur and has an inner diater of 4mm.
easy to reproduce. Parma delivered a small adapter with their fluo red lightweight spurs. the adapter fits in the spur and you add a 4X8mm bushin or bearing in the center. I think these spurs can still be bought but don't know about the fluo green adapters that came with them. The other adapter included was for a JR-X2; kind of gives away that does spurs came on the market long ago. I hae both solutions but never tried either with the standard slipper...
Return to “Kyosho Forum”
