Tool for gold shocks?
rangerg
Post by rangerg »
Is there a tool to use to help take off the tops of the Kyosho gold shocks (to avoid scratching them up every time with a pliers)? Kyosho had the included tool for the smaller red shocks with their unique design. I saw a shock tool for modern shocks, but it seems too big. Thanks for the help.
Eau Rouge
Re: Tool for gold shocks?
Post by Eau Rouge »
I have never had them on so tight that I needed a tool for them. Usually, I would stick a round Phillips screw driver about the size of the shock eyelet into the cap and hold the clean body with clean hands and open it. Works like a breaker bar, almost. If they are on so tight that you can't get them off that way, holding a freshly cleaned shock body while wearing a rubber glove, then opening using a driver in the eyelet usually does the trick.
Then don't make them that tight again when you rebuild them. :)
rangerg
Post by rangerg »
good idea - thanks Eau Rouge
I take them on and off by slipping an Allen key inside the hole and turning. That gives you more than enough torque.
Jay Dub
Post by Jay Dub »
You mean you have been using a pair of pliers on the cap to break it loose?
treehugger
Post by treehugger »
no no no ,you put the cap in the vice then that free,s up both hands for the channel locks 8)
rangerg
Post by rangerg »
Don't worry, I don't use pliers. I did that once a long time ago and realized it messed them up.
nvxwax
Post by nvxwax »
treehugger wrote:no no no ,you put the cap in the vice then that free,s up both hands for the channel locks 8)
LOL
Return to “Kyosho Forum”
