Melting insulation
stone7223
Melting insulation
Post by stone7223 »
Has anyone ever had the insulation melt off of a brand new NIMH battery after one charge and use?
drbelleville
Re: Melting insulation
Post by drbelleville »
How did you charge it, what size battery? what charger?
Has thanked: 3735 times
Been thanked: 1987 times
stone7223 wrote:Has anyone ever had the insulation melt off of a brand new NIMH battery after one charge and use?
Sounds like a connector issue. What kind of connectors are you running? What esc and motor? It sounds like the esc/motor combo is drawing more power than the connector can safely provide and is causing heat to back up into the battery wires. Need a little more info to give a definite answer though.
