Hot wire foam cutter
This is my hot wire foam cutter I threw together today. I'm goin to make it a little better, i just wanted to see if i could make it work, and with a better power supply i bet i could. Any ideas for a low budget power supply? as long as its from 4 to 9 volts and about 5 to 10 amps it will work, i can use a dimmer switch to adjust the heat.
- RC10Eh
Re: Hot wire foam cutter
If I remember correctly , guys would use a transformer from a train set . Your local flying club would be able to offer up some alternatives also .
Well i reworked the foam cutter today, i think its a little better now. I found an old computer and pulled out the power supply and im running it off the 5.4v 18 amp circut. Dosen't take long to cut through a 4 inch foam block.
- 1013 Views
Last post by tamiya
- 941 Views
Last post by AscotConversion
- 560 Views
Last post by slotcarrod
- 3231 Views
Last post by Moggie XL
- 21 Replies
- 2119 Views
Last post by Prince Steve
- 2290 Views
Last post by ChocoTaco73
- 906 Views
Last post by YZ-10
- 2673 Views
Last post by slapshot1979
Users browsing this forum: Bing [Bot],
Google [Bot],
morrisey0,
R6cowboy and 5 guests
