wheel nuts
sneako43
wheel nuts
Post by sneako43 »
I want to use nylon insert nuts on my 10T (1/4" rear and stock front axles). What size do I need?
SC10 -- FT B4.1
cyclepsych0
Re: wheel nuts
Post by cyclepsych0 »
8-32 for the rear and 5-40 for aluminum front axles, 4-40 if the fronts are the older steel ones... :wink:
sneako43
Re: wheel nuts
Post by sneako43 »
cyclepsych0 wrote:8-32 for the rear and 5-40 for aluminum front axles, 4-40 if the fronts are the older steel ones... :wink:
Thanks, I will check to see which front axles I have.
SC10 -- FT B4.1
SteveK
Re: wheel nuts
Post by SteveK »
Use these for the aluminum front axles:
http://67.199.85.166/main/productdetails.php?text=6222
They are the same ones for the shocks, and steering bellcranks, but the axles and bellcrank posts are 5-40 so don't mix them up with the shock nuts. You'll be able to tell right away as the nuts will feel very loose on the 4-40 screws.
Nuts for the steel front axles:
http://67.199.85.166/main/productdetails.php?text=6242
Rear axles:
http://67.199.85.166/main/productdetails.php?text=9834
There are a bunch of steel and aluminum nuts available. I like the low-profile aluminum ones, it looks like they only sell those in blue now. Avoid using the black 8-32 nylon nuts for the rear wheels, as I've found they strip very easily.
Been thanked: 1319 times
Re: wheel nuts
you know what the difference is between wheel nuts and deer nuts? wheel nuts are $2.00 a pack, deer nuts are under a buck.
:P :mrgreen:
SteveK
Re: wheel nuts
Post by SteveK »
scr8p wrote:you know what the difference is between wheel nuts and deer nuts? wheel nuts are $2.00 a pack, deer nuts are under a buck.
:P :mrgreen:
Re: wheel nuts
if your gonna give my comedic brilliance a facepalm, atleast give it a good one. :wink:
cyclepsych0
Re: wheel nuts
I don't know Scrappy... Steve's was pretty good to me! That guy coulda been in the truck forum of 10talk when that shot was taken for all we know.... :lol: :lol: :wink:
sneako43
Re: wheel nuts
Post by sneako43 »
Thanks SteveK...good one Scr8p.
SC10 -- FT B4.1
SteveK
Re: wheel nuts
Post by SteveK »
All the good ones had the 'facepalm' tagline at the bottom, I really didn't want to go that route. There was a good one with Piccard and Riker, but it was on a blog site and those don't show up right.
sneako43
Re: wheel nuts
Post by sneako43 »
SteveK wrote:All the good ones had the 'facepalm' tagline at the bottom, I really didn't want to go that route. There was a good one with Piccard and Riker, but it was on a blog site and those don't show up right.
"Make it so, Number One"
SC10 -- FT B4.1
SteveK
Re: wheel nuts
Post by SteveK »
Return to “RC10 Truck Forum”
