Losi XXT keeps melting off motor leads?
nvxwax
Post by nvxwax »
Ok i have only ran this truck twice and on the second run the wires de-soldered from the motor. Any idea what could cause this, The motor was also smoking a little.
Specs:
Duratrax 8T Racing Reversible ESC
Novak 2S lipo cutoff
Turnigy 4000 mAh 2s Lipo
17 T Venom motor
What is the most common cause of motor wires melting off.
Thanks
shodog
Been thanked: 91 times
Re: Losi XXT keeps melting off motor leads?
Post by shodog »
Generally the cause is over gearing. How hot does the motor get after a run?
nvxwax
Post by nvxwax »
I will have to look and see what pinion and spur im running. Thanks shodog
it could also be a long run time period. the brushed motors really don't like more than 10 minutes or so run time. with that lipo, I bet you can run it longer, leading to overheating.
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
If you spit on the motor and it sizzles its too hot.I havent seen anyone running heatsinks on brushless yet.Don
Return to “Losi Forum”
