Stealth transmission hole template
Can anyone use a stealth hole template (original, used only once)? I have enough stealth-ready tubs. It would be nice if someone could reproduce it for other forum members.
- cyclepsych0
Re: Stealth transmission hole template
I can't remember what these look like off hand....
Can you post a pic? If its what I think it is, I may be able to have these reproduced on a waterjet machine..
Sorry, no camera, but it is a small, maybe 2"x1.5" or so, steel plate and has four holes to bolt up to the rear arm mount holes with four guide holes for the stealth.
If you want it, PM me a mailing address and I will have it out this week.
- cyclepsych0
No worries. I found a pic of one in the BST section...
PM sent.
PM sent.
- Eau Rouge
- Been thanked: 5 times
Does anyone have one they can scan? I'm going to pop a few out in a vinyl decal that can be applied for a template to drill from. Simple and easy, but using the OEM template would be a big help.
dc
dc
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
I have a 1:1 scan I did a couple of years ago for some of the guys, let me see if I can dig it and then I'll post it to you Doug and whoever else wants it.
This is all very interesting!
- Eau Rouge
Perfect. I'm going to cut some templates once I make the artwork, and anyone who wants one is welcome to them for the cost of mailing.
dc
dc
- RC104ever
Bringing this topic back from the dead - can I get a copy of this template?
- Chris
Lots of cars...so many cars
I could use one as well. Though I hate to drill an 'A' Chassis. If only we had a plate that would mount stealth, then mount the whole plate to the original chassis.RC104ever wrote:Bringing this topic back from the dead - can I get a copy of this template?
- RC104ever
I was thinking the same thing. I figured it wouldn't be too hard to use something like a piece of extra plastic or aluminum, cut it to size, then drill holes in that.christhepcguy wrote:I could use one as well. Though I hate to drill an 'A' Chassis. If only we had a plate that would mount stealth, then mount the whole plate to the original chassis.RC104ever wrote:Bringing this topic back from the dead - can I get a copy of this template?
But I just ordered a B stamp chassis instead cause I'm too lazy, lol
- Chris
I could deffinatley use one myself! It would be awesome if someone had them on here? Anyone?
TOTALLY RADD!!!!
I made one of these (real rough from a piece of nylon without a tranny template) for TQ10 chassis that i didn't want to drill - worked really well though it creates havoc with the dogbones - raising the tranny (the "shim" has to be thick enough to support the tranny screws - mine was 1/8" 1/16" thick? I never measured) lengthens the distance from wheel hub to outdrives and therefore bumps would knock the dogbones out. CVDs solved that problem (unless you raise it really high) and I ran it a long time that way.christhepcguy wrote:I could use one as well. Though I hate to drill an 'A' Chassis. If only we had a plate that would mount stealth, then mount the whole plate to the original chassis.RC104ever wrote:Bringing this topic back from the dead - can I get a copy of this template?
HH TQ10
- Been thanked: 4 times
I have an original metal stealth hole drill template. If I get time I'll just draw it up in CAD complete with dimensions and I'll post it here so everyone can see it, print it, copy it, build a new one off of it, etc... Give me some time though. I'm about to switch jobs so time is short.
- ROH73
- Been thanked: 23 times
I measured/documented an entire chassis a couple of years ago on an optical comparator. Here's the rear section: http://www.tunneltwo.com/rc/rc10_chassis_rear_hole_pattern.pdf
Just print 1:1 and drill to your heart's content.
Regards,
Robert
Regards,
Robert
- 614 Views
Last post by JosephS
- 479 Views
Last post by a01butal
- 1025 Views
Last post by klavy69
- 987 Views
Last post by Lowgear
- 4455 Views
Last post by GodSpeed
- 1072 Views
Last post by KidAgain
- 1266 Views
Last post by Texas_Man2011
- 2539 Views
Last post by Phin
Users browsing this forum: Google [Bot] and 1 guest
