Shock sizes
- bully
- Been thanked: 6 times
Shock sizes
Hi all doing up graphite with stealth and am getting some shock towers off atlas to use, any thoughts and ideas on which shock sizes are best for front and rear? Any info welcome thanks
- cyclepsych0
Re: Shock sizes
If you're getting the CF atlas towers the front is made to use the longer .89" shocks off a B4. Rear should be stock length RC10 - 1.32" with limiters on the shaft to shorten them up a tad...
- rc10johnny
- bully
Re: Shock sizes
My buggy (pics in klien arm question post) appears to have 1.18" shocks all around is this right or am i measuring them wrong, seem to work ok but.
Re: Shock sizes
Suspension is a matter of preference, I mean, there are many shocks out there that will fit or can be altered to fit your buggy. Suspension adjustment, is like, almost infinite. The three main ways to adjust a shock are by spring rate, compression rate, and dampenining rate. There are other things to do also to adjust the suspension system, like, mountining location, and any adjustments to your suspension system will effect roll, flex, droop, ride higthe, and c.o.g., but no matter how you alter your vehicle from its current state, it will surely perform differently. Where you run and how you run are impoortant things to factor in also.
How do you want to change your current susp. system?
- 595 Views
Last post by jaro
- 1352 Views
Last post by Dr XX
- 459 Views
Last post by aeiou
- 979 Views
Last post by dimebag d.
- 827 Views
Last post by GeekSpeed
- 1750 Views
Last post by mark in wi
- 7830 Views
Last post by Bimdapogs
- 375 Views
