spur gear
- Has thanked: 28 times
- Been thanked: 957 times
Re: spur gear
72 is the smallest you can put on a 2.25 stealth's slipper. not sure about a 2.40's slipper........... maybe 78.
Re: spur gear
you can get them pretty much anywhere. but why would you want a 72 spur to use on a truck? that's way too small.
- THEYTOOKMYTHUMB
- Has thanked: 2122 times
- Been thanked: 1346 times
Re: spur gear
I smell a high speed run...!!scr8p wrote:you can get them pretty much anywhere. but why would you want a 72 spur to use on a truck? that's way too small.
Re: spur gear
You are correct good sir! The thing is a smaller spur really doesn't even matter anymore with the power brought forth with brushless engines. My buddy gave me a traxxas vxl system. I have to put it to use. LolTHEYTOOKMYTHUMB wrote:I smell a high speed run...!!scr8p wrote:you can get them pretty much anywhere. but why would you want a 72 spur to use on a truck? that's way too small.
Robert
- Been thanked: 12 times
Re: spur gear
you can get down to a 60T
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEY18&P=7
I have one of these nip and just tried it to confirm, it fits both the original and the b3 style slippers(doesn't look like it should but it does). Both slipper outer plates have tapered outer edges, and the 60t hugs the taper. pinion mesh/alignment will be very important to get right as the gear is actually smaller in diameter than the slipper.
- 974 Views
Last post by jackflak
- 409 Views
Last post by shredderboy
- 1926 Views
Last post by JK Racing
- 699 Views
Last post by Chemical
- 636 Views
- 757 Views
Last post by Phin
- 612 Views
Last post by Qballll
- 441 Views
Last post by sundevil67
