Frame "sticker"
Frame "sticker"
I keep hearing about a large sticker you used to able to buy that protected the bottom of the frame. I've done some searching but can't find anything other than references about them. Never any for sale. Are they a thing of the past? I found out my truck was carpet raced then basically retired. That would explain the reasonably clean frame and I would like to keep it that way.
RC10T Team Truck
Tamiya Clod Buster
The two I always wanted when I was a kid!!!
Tamiya Clod Buster
- Has thanked: 23 times
- Been thanked: 9 times
Re: Frame "sticker"
This is what i have used in the past. Good stuff that last's. http://www.stormerhobbies.com/cgi-bin/seekpart.pl?pn=JCI1155
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: Frame "sticker"
Anti-Scratch Chassis Protector #LC0909
http://www.rc10talk.com/viewtopic.php?f=69&t=12309
just let me know how many packs you need.
Re: Frame "sticker"
Thanks, when I get to that point I will give you a yell.
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
- Has thanked: 37 times
- Been thanked: 1346 times
Re: Frame "sticker"
if i could make a suggestion, why don't you start one thread about your truck and ask all of your questions in there? then you don't have to go huning all over the place if you need to go back to something, and you won't have to start a new thread every time you have a new question.
Re: Frame "sticker"
Well taken, but there is a method to my madness.scr8p wrote:if i could make a suggestion, why don't you start one thread about your truck and ask all of your questions in there? then you don't have to go huning all over the place if you need to go back to something, and you won't have to start a new thread every time you have a new question.
The other reason is I put my problem is in the title. That way if a search is needed by myself or someone else the problem is easy to find. And they don't have to dig through 500 pages of every bodies new Bling for the answer. Nothing is more frustrating than trying to find the answer (especially in a rush) and having to dig through multiple threads. The threads that contain the search word normally contain completely different problem or trying to sell the search word. I've had this happen more times than I can remember with my 1:1 car. But every forum is different. If that's not how this forum works, I will gladly change. No need to offend or make anyone mad. I'm just trying to get some information to put my T back together correctly.
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
- bully
- Been thanked: 6 times
Re: Frame "sticker"
J concepts chassis protection material comes in packs of two sheets, each sheet big enough to cover RC10 chassis easy.It is quite cheap and is made by 3m so it's good stuff.
Re: Frame "sticker"
+1 on the Jconcepts stuff, it's crystal clear and it doesn't leave a bunch of sticky mess when you pull it off.
Mark
- Brandon G
Re: Frame "sticker"
I have used the J concepts stuff. It works good if you run rarely and just want to keep it looking good. I have been racing my RC10 a lot and eventually it will wear through in the back. If I had to do it all over again knowing how much I was going to run the car, I would have left it off. Believe it or not, the stuff has quite a bit of weight to it for what it is. It also makes accessing the screws a real pain.
Stay away from the Associated sheet. If you ever take it off, you will understand why. (big sticky mess)
- 2392 Views
Last post by besty22
- 2654 Views
Last post by damian
- 1345 Views
Last post by Bormac
- 1912 Views
Last post by Dadio
- 1846 Views
Last post by Mindwarp
- 45 Replies
- 5624 Views
Last post by Kayne
- 65 Replies
- 10854 Views
Last post by vintage AE
- 1110 Views
Last post by 4times
