how to glue foam tire for my pan car
treehugger
Post by treehugger »
so im all most there with my new car but i would like to know how to glue foam tires does anyone know of an informative site that could explain it to a layman
regards Paul
i got this of rc tec its seems very messy is there a easier way
1. Roughen up the rim so that the tire cement will stick. A course emerycloth will do.
2. Put a lay of rubber cement (available at hardware stores) on both the tire and the rim, let dry for a hour or two maybe overnight, if you don't let it dry the cement will come off or will be sueeze toward one side of the rim.
3. Then get a coffee can filled with lacquer thinner and dunk both tire and rim for to soften the glue.
4. Slide the tire over the rim , set aside to dry overnight, then trim the tire.
markt311
Re: how to glue foam tire for my pan car
Post by markt311 »
buy mounted tires
Mark
treehugger
i guess but i like to recycle and my Celtic blood makes me cheep :lol: and it cant be that hard i will be practicing on is a nice big new asphalt lot so i was going to do some customs with hard foam on the outside and medium on the inside .
and besides that would make the truer i bought from bear just a big paper weight 8)
bearrickster
Post by bearrickster »
I use contact cement from Lowes. glue both sides let it dry and put them together.
LOSI RULES!!
Bearrickster's Rides
Eau Rouge
Post by Eau Rouge »
Rubber cement = no.
Contact cement = yes.
rc10johnny
Post by rc10johnny »
Hey Paul,if I remember correctly,I glued the rims,had a tomato paste can,slid the tires over the can,then over the wheels. I know I'm gonna here some S... about it but it worked. Johnny
rcguy5
Post by rcguy5 »
Just like you said in the first post but with contact cement should work.
You can also wrap wax paper around the rim after the glue sets then fold it over 90 degrees to stick out the side of the rim. Put the tire on and pull the wax paper slowly away.
Erich Reichert
Post by Erich Reichert »
This may sound a little odd but I've always used Woodweld. It gives you a little more time than rubber cement and is much stronger. 18 years of making my own dirt oval tires and I've never had one come off the rim
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
I glued new donuts on a set of rims and followed RC4less instructions down at the bottom of this page http://rc4less.com/Customer_Service/c32/index.html only difference was that I didn't buy the $20 quart +shipping of 3M contact cement from McMaster-Carr but instead bought a 4 oz. bottle of the Weldwood contact cement at Home Depot and used the MEK solvent as instructed. Everything worked as instructions had stated and after a days rest I trued up my new tires and they look great.
This is all very interesting!
treehugger
thanks this has been a great help now i need to do my research on how to hook thee tire up ive tried sugar water so far to no effect looks like another few hours digging through rc tec
rc10johnny
we used to use a rag soaked with WD-40 at the carpet track,sounds stupid when I saw them . but it worked. :shock:
Users browsing this forum: User avatarjuicedcoupe and 3 guests
