RC10T Dogbones
RC10T Dogbones
I'm trying to put together a RC10T Team Truck that was given to me. It is mostly complete. One of the pieces that I'm missing are the dogbones. I read somewhere that it took special ones. Does it take the normal dogbones? Also are they different than a buggies?
Thanks,
Thanks,
RC10T Team Truck
Tamiya Clod Buster
The two I always wanted when I was a kid!!!
Tamiya Clod Buster
- aeiou
Re: RC10T Dogbones
This would be what you're after:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2940&P=7
They are bigger than the ones for the buggies.
Re: RC10T Dogbones
Thanks for the info and link!!! I thought that was the one I needed. But I'd rather be safe than sorry.
The car came with new springs for the dogbones. Do they go on both sides of the dogbone, or just one. I haven't look to closely yet. But it looks like it has one spring on the wheel side. But the other is missing. I didn't look at the gearcase side.
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
- Has thanked: 36 times
- Been thanked: 1318 times
Re: RC10T Dogbones
Cool thanks again for the info. I'm slowly getting the time and parts I need to get it back together.
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
Re: RC10T Dogbones
The 1/4" axles take springs, but the 3/16" axles don't.
If you need to buy two dogbones, a full set of CVDs is only about $15 more and will work better. The T2 and later GT CVDs use 3/16" axles.
Re: RC10T Dogbones
Which are better? I assume that mine has 1/4 since one side has a spring. But maybe it has one of each!SteveK wrote:The 1/4" axles take springs, but the 3/16" axles don't.
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
Re: RC10T Dogbones
The 1/4" axles were the original design, using 1/4"x3/8" bearings. This worked OK on the RC10 buggy but the bearings proved a little weak when run hard with the bigger truck tires. The 3/16" axles use the same 3/16"x3/8" bearings that the front wheels use, which are a little more durable.
The wheels are not interchangeable between the two axles. Unless you are either starting from scratch or are having real problems with the 1/4" ID bearings, I don't think it's really worth changing over. If you have a lot of wheels for 1/4" axles, and the axles/CVDs/universals are all in good shape, you can get a set of heavy duty rear bearings and carriers from RPM.
Re: RC10T Dogbones
Thanks for the information Steve. I still need to check mine. But I'm pretty sure they are 1/4 though. Pretty cool though, one of the only times making something smaller, made the assy. stronger. If I would upgrade to CVDs I'd probably just make some spacers for 3/16 axles. That way I could run both 3/16 and 1/4.
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
Re: RC10T Dogbones
Yeah, the axle got small but the bearings got bigger, so it evens out. It only took them 11 or 12 years to figure it out LOL
1/4" axles:
3/16" axles:
Bearings:
Just that 1/16" makes a huge difference. The balls inside the 1/4"x3/8" bearings are so tiny, I can't imagine them taking as much abuse as they do.
Before Associated changed their axles, RPM released these carriers that use 1/4"x1/2" bearings:
1/4" axles:
3/16" axles:
Bearings:
Re: RC10T Dogbones
Well, you know you don't want to rush decisions like that too quickly!!!SteveK wrote:It only took them 11 or 12 years to figure it out LOL
RC10T Team Truck
Tamiya Clod Buster
Tamiya Clod Buster
- SmallScaleSmitty
- 909 Views
Last post by Zedmaster
- 1764 Views
Last post by mk-Zero
- 1717 Views
Last post by JPAE07
- 714 Views
Last post by 1of1547
- 910 Views
Last post by eco8gator
- 27 Replies
- 1955 Views
Last post by RogueIV
- 933 Views
Last post by Ste
- 1153 Views
Last post by Nobby Sideways
Users browsing this forum: Google Adsense [Bot] and 7 guests
