B2/B3 CVD Axle Spacing Problem
- DerbyDan
- Been thanked: 17 times
So, I fitted the MIP B2/B3 CVDs combined with 3/16" x 3/8" Avid bearings so I can run later 2.2" B3 wheels. I filed down some Losi axle spacers so that they were a nice fit between the roll pin & the bearing..... but on one run of the car I noticed one wheel was binding up causing the car to veer to one side.
On investigation it seems the roll-pin sits deeper into the wheel - which mean't that as I tightened up the wheel I was crushing the bearings - on running the car its enough to have caused them to get hot & collapse.
My queiry is to ask what do people do to ensure you don't crush the bearings? .... is there a kit (like what was available for the Losi XX) that includes a spacer to fit between the bearings inside the hub?
Thanks
Dan
Thanks
Dan
- Been thanked: 87 times
Re: B2/B3 CVD Axle Spacing Problem
get rid of the losi spacer. mine is set up with no shims on the inside and 2 thin shims on the outside. get it so it tightens down on the axle pin and then add shims till you get the right amount of play.
I use B4 axles and run the B4 outside spacer, it helps add a little width to the rear end
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEAB6&P=OW
http://www.amainhobbies.com/product_info.php/cPath/1_25_1450_824/products_id/2445/n/Team-Associated-Rear-Axle-Wheel-Spacer-T4-B4-GT-2
Mark
- DerbyDan
Thanks Mark for those links.... something to consider for sure
The Losi spacer I have fitted on the outside (between outer bearing & roll-pin) But I did have to 'thin' them down.... firstly it was to a 'perfect' fit.... I have now thinned them down a bit more so that when the wheel is fully tightened there still is a little bit of play - so we'll see how it goes once my replacement bearings have arrived
BTW There's no spacer fitted between the bearings inside the hub.
- 945 Views
Last post by floodx
- 2202 Views
Last post by Jay Dub
- 548 Views
Last post by burnsmonkey
- 1204 Views
Last post by rccars4sal
- 744 Views
Last post by cyber10b
- 850 Views
Last post by JosephS
- 1415 Views
- 2204 Views
Last post by mvelarde890
