Are some Ultima arm and pins different?
m_vice
Post by m_vice »
Question for the Kyosho knowledge people. :)
Anyone knows if the hinge pins on the Ultima, Turbo Ultima or even Ultima pro are different in diameter?
The reason I ask is because I replaced the arms of my Turbo Ultima with new ones and now I notice they have a lot of play and it is because my T Ultima pins are smaller that the holes on the arms :evil: .
The new arm i got are the UM-13 and I am using the original pins from my Turbo Ultima.
thanks.
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Re: Are some Ultima arm and pins different?
Post by RichieRich »
Maybe the original pins have worn down? I'm pretty sure the original Ultima and Turbo Ultima use the same suspension arms.
walfre
Post by walfre »
They are the same.
m_vice
Post by m_vice »
I might getting some new pins. But I am not sure yet because when I use the old original arms the pin don't play so much.
thanks.
highwayracer
Been thanked: 6 times
Post by highwayracer »
I would also check the bulkheads to make sure that those aren't worn down.
bdrmbully
Post by bdrmbully »
sometimes they are tight and sometimes they are loose. better to shim the play then having them too tight i think. the pins are all the same. no matter which ultima.
2nd place is just the 1st loser
Return to “Kyosho Forum”
