pinion gear for vintage RC10
I Have a 1990 vintage RC10,totally stock. I'm going to blow the dust of it and insall a 2.4 ghz radio and a brushless power system.(3300kv)
can anyone suggest what pinion gear to to use with the stock spur gear? I want to keep it conservative as I will not be racing or hard bashing, but just for fun.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: pinion gear for vintage RC10
32 Pitch 56t spur, to a 15t pinion might be in the neighborhood for ya
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
With a 3300kv I’d go about 10/56 or maybe even lower. It would pull a 15 tooth no problem, but it would be way too fast.
WimpTHEYTOOKMYTHUMB wrote:With a 3300kv I’d go about 10/56 or maybe even lower. It would pull a 15 tooth no problem, but it would be way too fast.
- THEYTOOKMYTHUMB
No, I’m just a terrible driver…Charlie don't surf wrote:WimpTHEYTOOKMYTHUMB wrote:With a 3300kv I’d go about 10/56 or maybe even lower. It would pull a 15 tooth no problem, but it would be way too fast.
And a bad liar, I would have said something about the driveline backlash on the outer 3/32 ball diff hub being too..............you get the ideaTHEYTOOKMYTHUMB wrote:No, I’m just a terrible driver…Charlie don't surf wrote:WimpTHEYTOOKMYTHUMB wrote:With a 3300kv I’d go about 10/56 or maybe even lower. It would pull a 15 tooth no problem, but it would be way too fast.![]()
Thanks for the info guys, I guess I'm whimp too because I would probably opt for the 10/56. I really don't want to beat this old buggy.
After giving it more thought, I should save the stock spur. If I were to go with a 78t 48p diff spur and a 23t or so pinion, would I have enough room to mount it
- flipwils11
- Been thanked: 19 times
Thread ressurection. Stripped the stock spur on one of my gold pans. Will this spur work (and if not, which one)?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS396&P=ML
- 730 Views
Last post by team rc10
- 1355 Views
Last post by jackflak
- 2550 Views
Last post by JK Racing
- 1892 Views
Last post by Jay Dub
- 3387 Views
Last post by losiXXXman
- 4119 Views
Last post by Eau Rouge
- 1656 Views
- 2921 Views
Last post by sandkil
