mid engine mounting
smurf420
mid engine mounting
Post by smurf420 »
is there any specific holes that need to be drilled or any major modification that needs to be done to convert the RC10 over...........i might be getting another Rc10 gold pan and wanted to do the mod to it
fastang
Re: mid engine mounting
Post by fastang »
Yes, 4 new holes need to be drilled and the tub needs to be hacked to clear the motor.
There is a tech section that most of these questions SHOULD be asked. Not on the buggy fourm!
i wouldn't do a mid motor setup on a tub chassis, but that's just me.
treehugger
Post by treehugger »
scr8p wrote:i wouldn't do a mid motor setup on a tub chassis, but that's just me.
and if you do i have one that someone has allready hacked up to suit if you feel like you have to defile a pan lmk and we can swap
smurf420
Post by smurf420 »
i would swap but i only have one car right now..........i'm waiting for the guy to e-mail me back about the other one.........from the description it's really scratched on the bottom and the nose plate is bent from hitting a tree........i figured it would be a perfect candidate for the mid motor conversion
a graphite chassis would be the best candidate for mid motor.
smurf420
Post by smurf420 »
as far as i know it's just a black pan car.........it might be a gold pan............the guy has two different ones and depends on which one he wants to trade to me............it might be a carbon pan or a graphite pan.........i can't remember right off hand and i deleted the e-mail(so stupid)..............we'll just have to see how things go but as soon as i get it i'll post pics of what i got/ if it was a steal or not
Group B
Post by Group B »
Lowrydesign did a mid-motor setup on a tub chassis.
He turned the motor to the other side, so that the rear suspension would load properly on acceleration (i.e. what must be done when one has a 3-gear vs. 4-gear trans.).
It jumped really flat.
Jeep-Power
Has thanked: 56 times
Been thanked: 52 times
Post by Jeep-Power »
scr8p wrote:a graphite chassis would be the best candidate for mid motor.
ditto!
I waited 'till I had a graphite to do it.
You can flip the 6 gear trans around & not drill any extra holes-- you will only use 2 of the 4 screw in the trans case, though.
With a Stealth, you will have to drill holes-- in that case, a pre-stealth chassis will work best.
here's my build
TallPeter ~ Hopeless Gearhead
Early Goldpans 'Fun Buggy' RC10C B44.3 RC8B3.1 RC12l 10LS Pro10
Has thanked: 356 times
Been thanked: 470 times
That motor is backwards, and while some of them may run for a bit that way-they won't for long. You want to move the topshaft to the other side of the car ( right side )
Group B
Post by Group B »
Also the rear end will unload from the torque of the motor accelerating, which can result in strange handling
Dave, have you posted any pics of the BMW 2002 in your avatar?
Group B
Post by Group B »
Charlie don't surf wrote:Dave, have you posted any pics of the BMW 2002 in your avatar?
Reggie,
I have not.
Its a '75 2002 racecar that belongs to a buddy.
I'll try to get some better pics from him soon.
smurf420
Post by smurf420 »
ditto!
here's my build
couldn't i just turn the trans around for it to work?
No spur shown, but the "normal" way to mid engine a car, and your diff needs to be flipped or it will loosen as you drive.
Turning the tranny around makes it a rear engine car :wink:
Users browsing this forum: No User AvatarGoogle [Bot] and 4 guests
