Does anyone have a definitive answer for this? After searching a good bit on this site and others, I will ask the question:
Will new size rubber (2.2) fit on the YZ10 ROAR sized wheels (5.5cm or 2.17in). I have a great set of the orange wheels and need new rubber for them. Can I put new rubber on there? If so, what is a good set of tires for the YZ10?
thanks all, and I am still learning a lot....
Old Wheels, New Rubber
- Toasted Coastie
- Toasted Coastie
Re: Old Wheels, New Rubber
Interesting solution. Does .03in make that much of a difference?tamiyadan wrote:i remember an old trick from like 1990 when everything switched from 2.0 to 2.1
we got thick rubber bands, and glued them to the rims, in the trench where the tire sidewall grooves into.
the rubber band thickened up the rim just enough to glue the newer 2.1 tires onto the rims.
you had to go back from time to time and touch up the sidewalls with glue, but back then these parts were a dime a dozen and tires would last like 2 weeks before you tried out a different tire combination.
we did the same trick to 2.1 to 2.2 rims and tires. the rubber band takes up the slight difference so you could glue the tire square to the rim, if you tried to glue things freehand without the rubber band, you would either pinch the sidewalls or glue the tire out of round.
- 995 Views
- 1362 Views
Last post by mk-Zero
- 907 Views
Last post by Diamond Dave
- 1472 Views
Last post by realoldschooldude
- 1418 Views
Last post by Mr. ED
- 492 Views
Last post by Blacktiger355
- 1849 Views
Last post by RC104ever
- 504 Views
Last post by railey72
Users browsing this forum: DotNetDotCom.org [Bot] and 4 guests
