Can't find a part
christhepcguy
Can't find a part
Post by christhepcguy »
After waiting just over a week for new idler gears and CV shafts, I found that I'm missing the bent e-clip that holds on the idler gear pivot to the metal plate in the 6 gear tranny. Anyone know where I can get one? Or atleast something that will work.
Also, will these fit the stock CE rear wheels?
That clip, tires, shock rebuild kit (along with some oil), and a paint job are all I need to finish my CE.
Thanks.
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: Can't find a part
Post by a01butal »
If you pm me your address I will send you an idler pivot bowed e-clip and washer, AE part # 6635.
This is all very interesting!
christhepcguy
a01butal wrote:If you pm me your address I will send you an idler pivot bowed e-clip and washer, AE part # 6635.
Thank You. PM sent.
fastang
Post by fastang »
You should be able to find that e-clip at any good hardware store. Just bring in the old one if possible and match it uo.
christhepcguy
fastang wrote:You should be able to find that e-clip at any good hardware store. Just bring in the old one if possible and match it uo.
Problem is I don't have the old one. The manual just calls it "large curved "E" clip".
fastang
Post by fastang »
:oops: I only read the important parts of the post :oops:
Sorry about that! :lol:
christhepcguy
Got the parts, put it all together and was able to run it. Thank You.
Now I just need to buy dome tires that fit. The losi ones I bought don't quite work.
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
If there is a slight gap between tires bead and the rim use rubber bands around the rim it grips at both surfaces and keeps from glue them in place.DON :lol: 8)
Users browsing this forum: No User AvatarGoogle [Bot] and 7 guests
