good place to get assortment of pinion gears
General info, Q&A.
FlyinGN
Post by FlyinGN »
In the stock pitch for a stealth..
Thanks!
aconsola
Post by aconsola »
http://www2.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=6pack
This is about the cheapest way to get a good selection. they are steel, nothing fancy, but they work. 6 gears for $11, the only way to get them cheaper is to watch ebay for used lots which come up occasionally.
-Anthnony
FlyinGN
Post by FlyinGN »
thanks!
aconsola
Post by aconsola »
Those are 48pitch, I think the stealth was available with either 32 or 48, so make sure you have te correct spur gear to go with it. I would reccomend sticking with 48 as they are a little quieter and plenty strong.
-Anthony
FlyinGN
Post by FlyinGN »
the 48 pitch is the more/smaller teeth correct?
aconsola
Post by aconsola »
yes.
Pitch is the number of teeth per inch diameter of the gear. the higher the pitch the more teeth for a given diameter and the smaller each tooth is.
-Anthony
