Ultima steering
Ultima steering
I was reading a review of the Ultima Pro in the 1989 RC Car Action. The car got a good write-up, but it mentioned that the steering should have been something better than bent wire to reduce slop. Another review of the Ultima in an earlier issue also mentioned the steering as a weakness. I have noticed this slop/looseness on used Ultimas, but what would be a good fix? What were the fixes back in the late 80s? After-market parts?
Thanks for the replies.
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
Re: Ultima steering
Are you interested in a period correct solution? The A&L steering system would work, if you can find one. Kyosho also made an upgraded steering set up too. If you want something easily available today, you can use the current RB5/Lazer parts but you'll have to source a rack for it to function properly. I suggest LA-17 which is still available @ shopkyosho.com.
- Been thanked: 10 times
Re: Ultima steering
What you aso just can do is put an turnbuckle between the two arms to connect them like Joel did...
mvh Isobarik
mvh Isobarik
Re: Ultima steering
Great suggestions, thanks. RichieRich - I just saw a picture in the magazine of the A+L steering system (it's bright yellow, right). Wow - I never knew that existed. I'm sure it was rare then - good luck finding one now, but I'll be on the lookout. I'll look into the other ideas - always good replies here, thanks!
- mikedealer
Re: Ultima steering
here's the custom Steering i made for my runner ultima through a couple revisions of it. the fiberglass bar is what i still use today and has been working great.
the A&L is great steering, probably hard to find on ebay, but they come up all the time, i needed this type in order to mount the servo and battery lengthwise in the car and for the car to steer like it does now. i never liked the way the battery mounted from side to side, hate that crap lol
- Attachments
- P8040016.JPG (56.26 KiB) Viewed 1401 times
- P8040014.JPG (76.53 KiB) Viewed 1401 times
- P8040013.JPG (61.62 KiB) Viewed 1401 times
- P8040011.JPG (52.36 KiB) Viewed 1401 times
- P8040008.JPG (57.58 KiB) Viewed 1401 times
- RichieRich
Re: Ultima steering
The parts I'm using are LA-17 (rack only), LA221b for the plastic steering arm parts, 92921 (Kyosho servo saver tube w/spring) and TOWC8480 (servo saver shaft). The last part is from Tower Hobbies.
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
Re: Ultima steering
This what I want to put on one of my next ultima projects along with a servo-mounted saver
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWTU0&P=7#
but this principle will work fine as a solution with the standard parts:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLVU8&P=7
- RichieRich
Re: Ultima steering
you could also search for a losi/houge alloy bellcranks but you may have to drill the bellcrank holes a little larger. I have them installed on a couple of cars, also you would have to go with ball studs and ball cups. much nicer set up then the old kyosho eye ball or even big fat ball stud.
2nd place is just the 1st loser
Re: Ultima steering
I put in an OTW-10 Kyosho steering set-up (recommended by RichieRich). I like it, but how do you mount the servo when you flip it like in MikeDealer's pics. First, I think I need a micro-servo and then are you drilling new holes.
- RichieRich
Re: Ultima steering
If you are using a standard wheelbase Ultima, you will need to use one of those low-profile servos. I am using an Ultima Pro XL chassis so, I can get away with using a standard servo. It's about 1/2 inch longer than the standard chassis.
Re: Ultima steering
Thanks RichieRich. So something like this: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPB45&P=7
With the standard chassis, I have to mount it sideways? Is there anyway to mount it like MikeDealer? I assume I'd have to drill holes, correct.
- RichieRich
Re: Ultima steering
Yeah, that should work. I have no idea how Mike was able to mount the servo. It looks like he cut the mounting ears off one side. Try sending him a PM and get it straight from the source.
- 1034 Views
Last post by crusaderlyf
- 1092 Views
Last post by RC10th
- 713 Views
Last post by Mr. ED
- 947 Views
Last post by RichieRich
- 1260 Views
Last post by bigred86
- 351 Views
Last post by coxbros1
- 696 Views
Last post by mikea96
- 1086 Views
Last post by woodall01
Users browsing this forum: No registered users and 19 guests
