RC10 buggy to truck conversion
been buzzing around a few different forum's and saw a article about a kit that will make it to where your RC10 buggy into a truck.......and thoughts , or info about this and is it worth it?
- Has thanked: 33 times
- Been thanked: 1178 times
Re: RC10 buggy to truck conversion
alot of companies had truck conversion kits for the rc10. proline, jg, andy's, a&l, crp..........
is it worth it? well, that depends on what you want. if you want to turn an rc10 into a monster truck, then yes, it's worth it.
- Been thanked: 496 times
the conversion kits were around when the truck craze started taking off, and guys were starting to race rc10 conversions against blackfoots, and other similar trucks.
the classes evolved enough that the manufacturers started selling real race trucks, ones that were car based, but utilized wider suspension to better absorb the terrain and provide a racing class chassis.
so if you are bashing and like the nostalgia, or want a cool piece of history to put on a shelf, then a conversion kit is for you. If you plan to race or want to experience a more race oriented vehicle, then look for an RC10T thru T4, with T4 (or T4.1) being the latest model available. Bear in mind that the farther you go back, the harder it is to find parts. Also associated isn't the only brand that sells a race class truck, losi, kyosho, etc all also offer competitive products.
The only hard part about a truck conversion these days is finding wheels with the right offset. Wheels for truck conversions had a lot of offset, to make the trucks wider and more stable. Ever since the RC10T, dedicated trucks have had long suspension arms and the wheels that were more deeply offset. The new wheels will fit, but the truck will be about two inches narrower than it would be with the more offset wheels.
hpi super star mt rims are easily found. they do kinda suck on the rc10 though. especially if your using the wide track front arms. if you use the 3/16 axles in the buggy, you can atleast use the losi adapter on the rear to widen the rear a little more.
- i crash cars
I have Superstar's. I think they are ok, why do you think they suck?scr8p wrote:hpi super star mt rims are easily found. they do kinda suck on the rc10 though. especially if your using the wide track front arms. if you use the 3/16 axles in the buggy, you can atleast use the losi adapter on the rear to widen the rear a little more.
i never said the "rims" suck. i said using them on the back of an rc10 (with the rc10 hpi adapter) that has the widetrack front arms sucks. the rear will be much narrower than the front. which is why i said using the losi adapters on the back will help that. they will push the rims out.
Yup, I have a set and the fronts have less offset than the rears. The fronts aren't fully offset either, but have more than the typical racing truck wheel, and more than the rears.scr8p wrote:i never said the "rims" suck. i said using them on the back of an rc10 (with the rc10 hpi adapter) that has the widetrack front arms sucks. the rear will be much narrower than the front. which is why i said using the losi adapters on the back will help that. they will push the rims out.
the best offset monster truck conversion wheels were darryl's A&L wheels they were super strong. i still run a set on my oval 10t but only on the right side for more offset. the coolest looking ones are the trinity baja's purple chrome, super rare and hard to find.
- Regular Member
I like my RC10 truck conversion. It drives great. Biggest weakness is the suspension travel in the front. But it is fun to drive and is quite fast.
The CRP Blackfoot wheels to RC10 adapters are available on eBay; I just had to buy a set to replace the ancient ones on my RC10 truck conversion:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350339763682
But they require a funky nut extension thing; which the JG adapter kit comes with:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380190031792
Also needs Tamiya axle adaptors for the front:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350340430686
Here is a photo of the truck conversion runner I have; with a graphite chassis and mid-motor mod; combination of the Andy's (rear) and JG (front) truck body mounts. I also just picked up a pair of new tires for it as well:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220588228064
does any one know where i can pick up the full conversion?........for another project RC10?.....i kinda wanna build a few different versions..... like the monster truck, a 4wd, and probably a mid engine.....then just one none modified (probably a shelfer) and one thats a runner..........can any one help?
any MT conversion would need to be pieced together, unless you get lucky on ebay and find a complete kit.
- 2512 Views
Last post by glowster21
- 27 Replies
- 4522 Views
Last post by NomadRacer
- 2599 Views
Last post by THEYTOOKMYTHUMB
- 2134 Views
Last post by MOmo
- 2506 Views
Last post by Lavigna
- 1503 Views
- 2317 Views
- 1783 Views
Last post by JOESGARAGE
Users browsing this forum: 1911Colt,
Amazon [Bot],
juicedcoupe,
RC10resto,
Tbot [Bot] and 3 guests
