RC10T Stealth 2.25:1 Q .need help
Hi everyone
I am new in the forum need advise pl
just buy from Tower the RPM RC10T Stealth 2.25:1 convertion.
a dont find new parts for it.
Do you have a list of parts or a place to buy them from.
Thenks Miki
Thenks Miki
- Has thanked: 37 times
- Been thanked: 1346 times
Re: RC10T Stealth 2.25:1 Q .need help
tower should have all of the parts for the stealth.
the motor plates have been discontinued for years. best place to find one is on ebay.
- rc10johnny
Big M ,tower has all the parts I just built one for my TQ,I did have to drill a B motor plate to fit. GOOD LUCK ON YER BUILD. JohnnySr
http://67.199.85.166/main/maincategory.php?category=3015.10txx&brand=assoc&nav=off1.10tnav
Associated still makes everything except the case, motor plate, gear cover, and apparently the old outer slipper clutch plate. The inner and outer slipper plates for the T3 will fit right in place.
- soniccj5
I would recommend getting a used 2:25 stealth for about 30-40$ off the bay. Otherwise you are looking at $80-100 for all new parts when all is said and done.
ED
ED
teanks guys
I have an old 2.25 transmission but the #6580
Diff Gear 45 tooth is "Capoot" dead .Im traing to find the diff gear #6580 a the
#6578 diff Outdrive Hub, left side. but it is out of stock .
faund a motor plate from TQ.
If sumeone have an idea i will be heppy to see.
BM
BM
- metallicats33
you gotta type the Part#'s in on Towers's search. If you just search RC10 not much will come up. A good amount of parts are there including almost all of the stealth parts
- burnsmonkey
Arent you suppose to be working?metallicats33 wrote:you gotta type the Part#'s in on Towers's search. If you just search RC10 not much will come up. A good amount of parts are there including almost all of the stealth parts
- metallicats33
Hey, I'm working!!burnsmonkey wrote:Arent you suppose to be working?
I'm here to make sure the Mechanics don't slack off. No one ever said I couldn't
Do I have to buy from Tower or can I buy direct from AE ??
Morten
Morten
Morten Max
- metallicats33
you can buy from AE, Just use the same method to find your parts. By entering Part#'s in the search field.
Join Tower's mailing list, they have some good discounts every month. The last few orders I've made I've saved more than 10% off the total ($35 off a $200 order, etc).
I checked, lots of the parts at Associated's site are out of stock. Search a lot of the online stores and try to maximize your orders, so you can cut shipping costs. I can't speak for the rest, but I know Tower does do international shipping.
I do get discount mails from Tower but I don't see any PayPal option on checkout ??
Morten
Morten
Morten Max
- 1156 Views
Last post by Savage03
- 819 Views
Last post by splaice
- 2085 Views
Last post by THUNDERSTRIKE1
- 31 Replies
- 6416 Views
- 2372 Views
Last post by VintageFanatic
- 24 Replies
- 2428 Views
Last post by msedsp
- 64 Replies
- 8730 Views
Last post by askbob
- 1409 Views
Last post by LTO_Dave
Users browsing this forum: Arexera [Bot] and 4 guests
