Hi Guys
I,m putting a TRX3 together and have come across two different types of steering blocks,
First, part No.2737 which is the same as fitted to the TRX1 and when fitted to the "3", spacers
are used to vary the front ride height, also the steering bellcrank spacers are moved accordingly
to eliminate bump steer
Second part No.2536 there are no spacers required to mount these in the castor blocks
Which set should I use? and what differences between the two will I notice?
Thanks in advance
Steering Blocks
Re: Steering Blocks
The advantage of having the steering spindles adjusted with spacers is that in the "low" position, you can readjust your ride height with spring preload (to get back to the same ride height you had as in the high position). and your front arms will be at an angle (with relationship to the ground) that allows the front end to handle rutted turns more easily. In the high position, with the chassis at its normal ride height, you will have a slighlty more progressive front suspension that will usually result in more steering and a more responsive car. This is a very minute adjustment, and to undersand it best you need to try it back to back on your car to feel what that change makes. I personally like the adjustible over the static for this very reason. -Jeff
- 1564 Views
Last post by graemevw
- 935 Views
Last post by aeiou
- 1240 Views
Last post by SRTracer121
- 1443 Views
Last post by LJH
- 741 Views
Last post by Braydun
- 1401 Views
Last post by RC10th
- 907 Views
Last post by slow_jun
- 1201 Views
Last post by LJH
