how are you mounting your batteries?
General info, Q&A.
superfly
Post by superfly »
Umm my batteries in the shotgun format dont seem to fit very well in the gold chassis I'm building. Length wise they are too long and would never fit in the holder and if i cut the end off the holder the battery will stick out of the end and get too close to the servo mount. I ripped open a battery and removed the plastic end cap and then taped it up and that fits better but it looks bad. And forget mounting it cross ways...way tooo tight. All my packs are the shotgun stick packs and I'm thinking that the side by side packs must be better however i dont have any of them...what do you guys do? I'm thinking I'm going to have to cut up a regular holder or make something up... :(
badhoopty
Has thanked: 164 times
Been thanked: 148 times
Post by badhoopty »
i usually trim the front off the battery cup enough for the wire and that plastic 'bulge' on the end to clear, leaving a little on both sides to hold the pack. i've also dremeled out the inside area of the rear bulkhead to gain some more clearance for a stick pack.
superfly
Post by superfly »
yeah i think i'll try that dremel to the bulkhead trick i dont want to cut up all my packs :(
badhoopty
Post by badhoopty »
i think alot of the problem with the stick packs isnt the cells themselves but the honking plastic end caps the batteries have on them.
dont forget on the rear bulk the 2 screws that attach the side to the side of the pan. you may want to use shorter screws to gain clearance so the pack can slide past them.
Whiskers
Post by Whiskers »
I'm old school, and I don't have even 1 stick pack. All my packs, even the ones I just bought a month ago, have been taken apart and assembled into side by side packs.
I also don't own any battery or motor plugs, :D , all my stuff is still hard wired.
It's the way we did it in '90 - '94.
Users browsing this forum: No User AvatarYandex [Bot] and 1 guest
