b4 wheel conv. with rpm arms need cvd?
62 bugzilla
Post by 62 bugzilla »
I'm converting a buggy to b4 wheels and I have some rpm arms that I believe are the andy arm length and need to know what cvd to use and outer hub? I think I can use the b44 which is what they use on the klein arms but not sure if the rpm are the same width. I searched around and didn't find my set up. Thanks for the help.
Has thanked: 357 times
Been thanked: 470 times
Re: b4 wheel conv. with rpm arms need cvd?
If the arms you have are RPM Worlds arms then the Klien arms are a direct copy
PBR Allstar
Post by PBR Allstar »
Here's very comprehensive list of the parts needed to do the wide track conversion that I posted on page 13 of the what's old is a lot newer thread.
http://www.rc10talk.com/viewtopic.php?f=35&t=5483&start=180
Mikeyboy
Post by Mikeyboy »
You should measure your arms from the hingpin holes and compare to a stock arm set. There are lengths posted somewhere on the forum. If you have the RPM worlds arms, then you can use the b44 cvds and RPM GT hub carriers.
62 bugzilla
Thanks alot that what I thought but just wanted to make sure.
