- Incredible_Serious
- Has thanked: 1353 times
- Been thanked: 819 times
If they're hex rear, bearing front, 2.0", and the fronts are pretty narrow, I'd guess MadCap wheels....
I checked out some pictures of Madcap wheels and you're probably right Alex.
Thanks.
Thanks.
- RC10resto
- Has thanked: 1052 times
- Been thanked: 413 times
Do you think the exhaust system is original? I haven't found one like it yet.
- Has thanked: 792 times
- Been thanked: 2264 times
Boat or aircraft pipes with some Lowe's thrown in. Definitely not stock (stock was nothing, you supplied the muffler system )
Factory Works website
Cool thanks for the information, I found this on eBay and wanted to get some info on it. I thought about bidding on it, but I may just send the seller an email letting him know more about it. It listed very poorly with no information. It seems like these are fairly valuable.
- Has thanked: 13 times
- Been thanked: 78 times
Yes basically a CK800, but the complete rear end with diff and wheels is missing also the motor pinion gear. If you can find the missing parts, this will be an expensive project.
I have not seen the auction until now. Seems hidden somewhere.
- klavy69
- Moderator
- Has thanked: 544 times
- Been thanked: 255 times
damn...it was an expensive start of an expensive projectV12 wrote:, this will be an expensive project.
Wheel adapter help please. The set of 4 are Schumacher fit ment but to what wheels? The pair have one way axle on them and are for the same wheels
P
P
Look like for PB Mini Mustang or Hotshot wheels, the set of four..... but honestly never seen them before!
- Jirka
- Has thanked: 18 times
- Been thanked: 15 times
The other adapter may be for Optima (MID). Do they have one way bearings in them? And like Alex just wrote they require Hotshot type wheels.
Jirka
Jirka
- 59 Replies
- 8583 Views
Last post by Diamond Dave
- 431 Replies
- 39187 Views
Last post by Eccentric
- 102 Replies
- 15489 Views
Last post by mikesofunny
- 67 Replies
- 8781 Views
Last post by bearrickster
- 321 Replies
- 27389 Views
Last post by tazz888
- 448 Replies
- 35441 Views
Last post by MelvinsArmy
- 351 Replies
- 34518 Views
Last post by Frankentruck
- 2187 Views
Last post by mrlexan
Users browsing this forum: DotNetDotCom.org [Bot] and 1 guest
