Battery Help
Twiceblown351
Battery Help
Post by Twiceblown351 »
How much are you supposed to discharge NIMH and NICD Battery? To what V?
I just got a Hyperion EOS0606i charger. And I'm trying to tune up some of my Batteries. And I'm not shore how to go about it.
Thanks
Twiceblown= 93 F150 Lightning
393 and two turbos @ #10Psi
= 10.90@126 in street trim
8rad
Has thanked: 9 times
Been thanked: 38 times
Re: Battery Help
Post by 8rad »
Typically Nimh cells should never be discharged below 0.8V but can be as high as 1.1V depending on the cell. 0.9V is a good general guideline. You should consult the specs for your battery and use the manufacturers recommended values.
m2fit4u2
Re: Battery Help
Post by m2fit4u2 »
I have that same charger and do I love it :D
None of my Nimh battery's are top of the line. When I first received the charger I just just performed a discharge/charge cycle and it seemed to wake up the batteries better than my Integy Peak charger did.
Users browsing this forum: No User AvatarBing [Bot] and 2 guests
