painting ?
rctenracer
Been thanked: 81 times
painting ?
Post by rctenracer »
Do you cut out the body first? Also can you thin out faskolor with water?
slotcarrod
Been thanked: 45 times
Re: painting ?
Post by slotcarrod »
rctenracer wrote:Do you cut out the body first? Also can you thin out faskolor with water?
I like to pre cut, drill and sand all my bodies before painting. I have not done this yet but I was told by a pro painter, the best stuff to thin Faskolor is Windex, the blue stuff!
Eau Rouge
Re: painting ?
Post by Eau Rouge »
The blue stuff will slightly tint whites and light colors. The best I have found is CLEAR window cleaner, like the Armor All Auto Glass cleaner...
As for trimming, it's easier for painters to paint uncut bodies, but harder to trim them later accurately. As a painter, I would rather trim then paint my own stuff. If I am getting bodies from someone else, I won't touch it if it has been pre-trimmed.
soniccj5
Re: painting ?
Post by soniccj5 »
I used water and did not have any problems with my airbrush. Kept the air pressure around 35.
ED
Bormac
Has thanked: 20 times
Been thanked: 11 times
Re: painting ?
Post by Bormac »
I always pre trim every lexan shell I want to paint. That way you can check and re-check it fits to your chassis properly.
-Jason.
Still known as- bormac
