Front setup help
General info, Q&A.
TViz
Front setup help
Post by TViz »
Hey folks,
Need some help. Working on the 2.2 wheel conversion and World's front end. I've gotten the extended aluminum GT axles but they are not fitting into my RC10 steering blocks at all. I tried jamming them in there but I can't get the pin through because the axle does not go into the steering block far enough for the holes to match.
What do I need to make this work? B4 steering block and caster blocks? Will I need to do any modifying? I'm seeing people posting "drilling to make the hinge pin fit". Need some help. Here's what I am working with right now.
Dynotech a arms for the front
T2 Shock Tower
10T Bulkhead
Stock (from my graphite) caster and steering block
JConcepts Rulux B4 Wheels
Has thanked: 33 times
Been thanked: 1178 times
Re: Front setup help
as long as you have the correct knuckle (6221), the axles should go right it.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2524&P=SM
TViz
Post by TViz »
Okay, I don't have those knuckles. Will those knuckles fit my original graphite stock castor blocks?
yup
TViz
Post by TViz »
Thank you once again scr8p
