Larger Brat wheels and hub options ?
My buddy has the re-released Brat.
What options, that you know of, would work for larger wheels that will work with the Brat.
(We're only concerned with axle/hub/wheel mods, if the body needs to be cut to make room, that's ok.)
He'd like the Monster Beetle type, preferably.
Even if hubs and axles or whatever need to be replaced, what suggestions do you have?
Thanks for anything you can offer.
JRX2 in the late 80s... have since come to my senses with the RC10T, yes of course it's vintage! Wife is always destroying her Tamiaya LunchBox to call me her personal mechanic a few more times. Enjoying the fresh build of an RJ Speed Digger.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: Larger Brat wheels and hub options ?
So essentially he wants to make a Mud blaster? easiest way to put 2.2 wheels on is to pick up a set of Blackfoot wheels and a CRP monter truck front wheel adapters
It doesn't do so well in the rough and bigger stuff.
With such small wheels/tires it gets high centered alot.
He had a monster beetle at one point, and liked the way the tires wore in and their performance as well.
It also just needs to look beefier.
- highwayracer
- Been thanked: 6 times
Another option would be to use the HPI star wheels (for a truck). These wheels come with the adapters to run on the early tamiya cars.
- highwayracer
I just tested the fiment of the HIP wheels on my frog and the fronts bolted on without any modifications.
The front adapters that are suppose to be used for the blackfoot increases the bearing spacing so that it fits on the blackfoot front axle. Since the frog's axles are narrower, the spacers are not needed...thus, a direct fit.
The only thing he may need to do is replace the fornt bumper...since the wheels and tires will be larger.
There are 2 versions of these wheels. He needs to use the version that has a higher positive offset (the SS Monster wheels):
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXM872&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXM876&P=7
The lower offset wheels are used on the LXT and the RC10T
hope this helps...
highwayracer
hope this helps...
highwayracer
Thank you highwayracer!
That's the exact type of advice we're after.
I'll pass it along.
I'll pass it along.
- 1680 Views
Last post by Martco78
- 22 Replies
- 4602 Views
Last post by mdutcher
- 758 Views
Last post by cautrell05
- 718 Views
Last post by RC104ever
- 2098 Views
Last post by SteveK
- 863 Views
Last post by gula
- 56 Replies
- 9180 Views
Last post by aip47-2008
- 1625 Views
Last post by isitafox
Users browsing this forum: No registered users and 17 guests
