RC 10 Stelth trannys questions
OK Can one of you tell me if there is gear change between the Buggie and RC 10 Truck trannys. Would I see a difference in gearing. If I put a truck stelth into an RC 10 Gold pan?
I have taken THE Top shaft compleat out of a T 4 counted the number of teeth on the top gear and there the same. This way you can use the newer spure gear onto the Standard RC 10 and 10 T. BUT you have to compleatly change everything. on top. Except the bearings they are the same.
IT all works good.
BUT now I was wondering is there a gear difference in the finial drive? on the 2 stelth trannys. IF not that will save me some extra work this week on my oval GOLD pan that I just put together this week.
thanks you DON
IT all works good.
thanks you DON
- Charlie don't surf
- Has thanked: 365 times
- Been thanked: 482 times
Re: RC 10 Stelth trannys questions
Original stealth 2.25, T2 stealth 2.60, b2/b3 stealth 2.40, B4/T4 stealth 2.60
OK so your saying both trannys were the same between the RC 10 and 10 T truck.? I knew there was diff between the later ones. IF the older ones were the same that will save me some prolbems and work later . Get back to me on this one thankyou agian. I am getting ready to some changing and hoping they are the same except for spures gears. DON
Other than the stock 81t spur (buggy) and the 87t spur (truck) they are the same
- mikedealer
if you are using a really fast brushless motor, i recommend the rpm 2.65 conversion kit, it will accelerate better with modern size tires and gearing will be smaller, or larger, or whatever lol
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEV49&P=7
OK thank you that will save me a few problems later down the line when I do some changing. I was just about ready to out of my RC 10 T and pull out the buggie stelth..
NOW If you ever want to up date your early stelth install everthing out of a later RC T or RC T 4 all of the top gear assembley will go right in just be sure to change everthing on TOP then you can run the newer Spure. I have done it a few times for the older spure gears was starting hard to fine for me that was why I up dated my Stelth. THE top stell gear teeth is the same as the older one. BUT everthing elest is different on the newer tranny. BUT like I say the top gear is the same. IT Works good. BUT You have to replace everthing .
- 430 Views
Last post by bearrickster
- 1694 Views
Last post by Eau Rouge
- 981 Views
Last post by aggpm09
- 1616 Views
Last post by voodoolite
- 1783 Views
- 1145 Views
Last post by LoboNYC
- 1848 Views
Last post by Chewbacca
- 22 Replies
- 2393 Views
Last post by DMAT
Google [Bot],
RogueIV and 7 guests
