RC10T gearing help.
- vintage racer
RC10T gearing help.
Hi all,I have been running my 10t a fair bit lately and am having trouble finding the correct gearing for my CO27 stock motor.Im running a 90 tooth spur,this is the biggest I can find and a 16 tooth pinion and it is getting way too hot.Is anyone else out there running a rebuildable stock motor that could tell me the right gearing?Thanks,James.
- Been thanked: 12 times
Re: RC10T gearing help.
what tires are you running? are you racing or bashing? overall tire height can make a big difference in gearing needs.
- Has thanked: 7 times
- Been thanked: 42 times
You're going to have to go to a smaller pinion. The original Stealth gear ratio wasn't really truck+stock motor friendly. If you can, pick up a MIP Change Box or the RPM conversion. They both raise the internal ratio to where you can use reasonably sized spur and pinion gears. If neither of the transmissions are an option, pick up some small pinions and drop a few teeth.
- 2119 Views
Last post by i crash cars
- 1308 Views
Last post by spru
- 1977 Views
Last post by ca-rj
- 363 Views
Last post by klavy69
- 6204 Views
Last post by JK Racing
- 387 Views
Last post by geeforce59
- 1035 Views
Last post by mark in wi
- 30 Replies
- 7167 Views
