urget stealth and 6 gear questions
General info, Q&A.
87fierogt
Post by 87fierogt »
hey guys i got a few questions that i am trying to find out pretty quick. i have a stealth that was in a worlds chassis(i dont know if its orig) i need to know the diff ball size along with the slipper clutch spring/nut and pads part number and am i able to buy the balls,sping and nut,and slipper pads anywhere?
also whats my best bet to find a 6 gear spur gear/bearings or bushing set?
thanks in advance,
alex
speed r/c taking car of all your rebuilds/restore/used and new custom builds/and anything in between pm me for quotes and`pics of previous builds
Brandon G
Re: urget stealth and 6 gear questions
Post by Brandon G »
diff balls: 3/32" 6581
pad 6585
nut/spring 6587
Type the # into Tower hobbies search, they have them all in stock.
I buy all of my bearings from avidrc.com $1 ea, you just need to know the size and qty you need.
I had this saved in a file on my pc:
Associated Stealth Transmission (1st gen) part list:
6604 Motor Plate
6566 Felt spacer
6608 Gear cover
6569 Plate spacers
6583 Slipper hub inner
6584 Slipper hub outer
6587 Slipper spring & nut
6585 Slipper pad
6596 Bushing
6594 Bushings
6693 Spur gear
6575 Diff nut
6582 Diff spring
6580 Diff gear
6581 Hard diff balls
6589 5/32 X 5/16 bearings (2)
6906 3/16 X 3/8 bearings (5)
6903 3/8 X 5/8 bearings (2)
6578 Outdrive half
6577 Outdrive half
6573 Diff thrust washers
6574 Diff thrust balls
6579 Diff rings
6565 Case
6571 Gear
6572 Roll pins
6570 Idler gear
Associated 6 gear transmission parts list:
6605 Gearbox
6606 Bearing adapter
6607 Motor Plate
6608 Gear cover
6609 Drive gear pivot
6610 Idler gear pivot
6611 Spine plate
6612 Outdrive gear (2)
6614 Idler gear set
6617 Diff tube
6618 Diff shaft with pinion
6619 Hard diff balls
6620 Diff pinion left (small hole)
6621 Diff pinion right (large hole)
6623 PTFE bushing
6624 Diff outer hub
6625 Drive rings
6626 Std diff balls
6628 Diff spring
6633 Felt seal
6634 Tranny screw and e-clip set
6693 Felt seal
6901 Std 3/16 X 5/16 bearings (2)
6902 Flanged 3/16 X 5/16 bearings (6)
6903 Std 3/8 X 5/8 bearings (2)
87fierogt
Post by 87fierogt »
you are THE MAN!!!!! i sold an rc10 and its late so i wanted to order the parts to finish it since it was late to him.
