Question about Tamiya Juggernaut
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Does anybody know what the difference is between the Tamiya Juggernaut and Juggernaut II. I've looked at the boxes and for the life of me can't see any real difference, must be something.
This is all very interesting!
- mrlexan
- Been thanked: 12 times
Re: Question about Tamiya Juggernaut
the "II" and the " " at the end of the name maybe?
www.gojammedia.com
www.gojammedia.com
The stickers and body color?
The important difference is the internals on the axles. The originals apparently would self destruct rather quickly.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Redesigned axle tops. The originals grenaded after only a few runs
- a01butal
ok, now I've got some homework to do or can you tell from a picture if I posted one?
- a01butal
Body color on this one is white and I have sticker sets for both "II" and " ".aconsola wrote:The stickers and body color?
- civilguy
- Has thanked: 5 times
- Been thanked: 14 times
A few runs should tell you.
If I recall if you had a Jugg 1 you could get replacement axles, so it may be tough to tell them apart by mechanicals.
Check out the two entries here: http://tamiyaclub.com/car.asp?id=238
http://tamiyaclub.com/car.asp?id=261
Is there a raised area for the receiver on your chassis?
Jeff
Jeff
- a01butal
Bingo, motors are mounted inboard and side by side, answer is Juggernaut II.
Thanks Jeff you are the man.
- longboardnj
click on these links ...click on manual... then show page 8 on each.. you will see.. are you getting 1??? these trucks are so cool....if you want a cool scale lookin monster truck all stock (besides adding ballbearings) get it..if you want a great off roader get a txt1civilguy wrote:A few runs should tell you.![]()
Jugg 2 had redesigned front axle internals- Tamiya added extra bearing supports to the drive pinions and carriers. Jugg 1 owners could get the upgrade kit from Tamiya. I remember ordering a Jugg 1 and being told a week later they had been discontinued. Too bad, they are a collectors item now.
- a01butal
Jeff you are still the man but both Juggernauts have side by side inboard motors, this was in comparison with the Clod not the Juggs I + II, I got impatient and didn't read all the way through, my mistake.a01butal wrote:Bingo, motors are mounted inboard and side by side, answer is Juggernaut II.Thanks Jeff you are the man.
Still not sure which I have, whatever it's probably upgraded to correct the problems but this is strange you can't easily identify which is which.
- civilguy
Jugg 1 manual page 19 shows the chassis part where the battery lays and the rx mounts. In the Jugg2 the rx area is raised (page 21)-- the same spot looks flat on the Jugg1. That is probably the easiest way to tell them apart. The boxart colors were different, but the body was the same. The decal sheet changed.
Either way... cool truck for a Ford.
Jeff
Jeff
Jugg2 axles had a "2000" stamped into the housing to tell the difference. I believe there was also an external heatsink added to the transmission. Unless a Jugg had the later drivetrain installed you might be able to tell the difference by this.
- MelvinsArmy
- Been thanked: 11 times
Bingo. Look for the date stamp. Jugg 1's have no stamp. TXT's were beefed up further and I believe they are stamped 2001 or 2002, whichever year they came out. The axles are all you have to worry about. If you've got Jugg 1 axles, you can easily convert your truck to TXT specs and it will be nearly indestructible.Mazdaj wrote:Jugg2 axles had a "2000" stamped into the housing to tell the difference.
- 2512 Views
Last post by delsami
- 25 Replies
- 8970 Views
Last post by Puffdogg
- 708 Views
Last post by airdreams1
- 1289 Views
Last post by FasterLouder
- 1477 Views
Last post by flipwils11
- 783 Views
Last post by Tadracket
- 539 Views
Last post by RC104ever
- 1295 Views
Last post by JK Racing
