rpm rc10t chassis good or bad??
General info, Q&A.
longboardnj
Post by longboardnj »
my buddy wanted to get a rpm rc10t chassis.. whats good about it?? whats bad about it?? any weak points or points to look at for cracks.. does it take stock parts, or do you need rpm parts like front and rear bulkheads, steering parts, trans mounts, rear arm mounts?? if it doesnt take all stock parts what rpm parts do you need? worst case id like to to know what people thought of this chassis ..
Has thanked: 356 times
Been thanked: 470 times
Re: rpm rc10t chassis good or bad??
Great chassis,and they will accept all the normal 10t running gear exept-bellcranks & battery box
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
Post by lowrydesign »
the only drawback of the ultramolded series is mounting your electronics, not much room on the chassis
73cuda2
Post by 73cuda2 »
I had my electrics mounted on the battery tray lid. It worked out great. I bought it because the OEM pan kept tweeking and started to tear where the back arm mounts are. I was running mod truck with a 17 turn Saphire motor back in the day. The truck jumped alot better with the RPM chassis.
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
73cuda2 wrote:I had my electrics mounted on the battery tray lid.
...and that is the place where you are supposed to mount them.
Come and visit the stable
